Lesson 11: Photoresistor Module
The Raspberry Pi does not have analog input capabilities, so it needs a module like the PCF8591 ADC DAC Converter Module to read analog signals for processing.
In this lesson, we’ll learn how to read from a photoresistor module using a Raspberry Pi. You’ll find out how to connect a photoresistor Module to the PCF8591 for analog-to-digital conversion and monitor its output in real-time with Python.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
import PCF8591 as ADC # Import PCF8591 module
import time # Import time for delay
ADC.setup(0x48) # Initialize PCF8591 at address 0x48
while True: # Continuously read and print
print(ADC.read(1)) # Read from Photoresistor at AIN1
time.sleep(0.2) # Delay of 0.2 seconds
print("Exit") # Exit on CTRL+C
Code Analysis
Import Libraries:
This section imports necessary Python libraries. The
PCF8591library is used for interacting with the PCF8591 module, andtimeis for implementing delays in the code.import PCF8591 as ADC # Import PCF8591 module import time # Import time for delay
Initialize PCF8591 Module:
Here, the PCF8591 module is initialized. The address
0x48is the I²C address of the PCF8591 module. This is necessary for the Raspberry Pi to communicate with the module.ADC.setup(0x48) # Initialize PCF8591 at address 0x48
Main Loop and Reading Data:
The
tryblock includes a continuous loop that consistently reads data from the Photoresistor module. TheADC.read(1)function captures the analog input from the sensor connected to channel 1 (AIN1) of the PCF8591 module. Incorporating atime.sleep(0.2)creates a 0.2-second pause between each reading. This not only helps in reducing CPU usage on the Raspberry Pi by avoiding excessive data processing demands, but also prevents the terminal from being overrun with rapidly scrolling information, making it easier to monitor and analyze the output.try: while True: # Continuously read and print print(ADC.read(1)) # Read from Photoresistor at AIN1 time.sleep(0.2) # Delay of 0.2 seconds
Handling Keyboard Interrupt:
The
exceptblock is designed to catch a KeyboardInterrupt (like pressing CTRL+C). When this interrupt occurs, the script prints “exit” and stops running. This is a common way to gracefully exit a continuously running script in Python.except KeyboardInterrupt: print("exit") # Exit on CTRL+C
