Lesson 14: Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
In this tutorial, you’ll learn to operate the MAX30102 sensor using a Raspberry Pi, streamlined through the use of the open-source MAX30102 Python driver available on GitHub. This approach makes it easier to interface with the module, allowing you to focus on understanding the basics of sensor data collection and analysis. Ideal for novices, the project provides hands-on experience with sensor implementation and Python coding on the Raspberry Pi platform.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
../_images/Lesson_14_MAX30102_pi_bb.png
from heartrate_monitor import HeartRateMonitor
# Print a message indicating the sensor is starting
print('sensor starting...')
# Set the duration for which the sensor data will be read (in seconds)
duration = 30
# Initialize the HeartRateMonitor object
# Set print_raw to False to avoid printing raw data
# Set print_result to True to print the calculated results
hrm = HeartRateMonitor(print_raw=False, print_result=True)
# Start the heart rate sensor
hrm.start_sensor()
    time.sleep(duration)
    print('keyboard interrupt detected, exiting...')
# Stop the sensor after the duration has elapsed
hrm.stop_sensor()
# Print a message indicating the sensor has stopped
print('sensor stopped!')
Code Analysis
  1. Importing Modules
    • The heartrate_monitor module is used to interface with the sensor. For more information about the heartrate_monitor library, please visit doug-burrell/max30102 .
    • The time module helps in managing the duration of the sensor data collection.
  2. Initializing the Heart Rate Monitor
    • A HeartRateMonitor object is created with specific print options.
    • print_raw controls whether raw sensor data is printed.
    • print_result controls the printing of processed results (heart rate and SpO2).
  3. Starting the Sensor
    The start_sensor method activates the heart rate sensor.
    hrm.start_sensor()
  4. Running the Sensor for a Set Duration
    • The program sleeps for a specified duration, during which the sensor collects data.
    • time.sleep(duration) halts the program for the given number of seconds.
  5. Stopping the Sensor
    After the duration, the stop_sensor method is called to stop data collection.
    hrm.stop_sensor()
  6. Finalizing the Program
    Prints a message when the sensor stops.
