Lesson 17: Rotary Encoder Module
In this lesson, you will learn how to connect and program a rotary encoder with a Raspberry Pi. We will provide step-by-step instructions on writing a Python script that monitors the encoder’s position and button state, with outputs displayed in the console.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import RotaryEncoder, Button
from time import sleep
# Initialize the rotary encoder on GPIO pins 17(CLK) and 27(DT) with wrap-around at max_steps of 16
encoder = RotaryEncoder(a=17, b=27, wrap=True, max_steps=16)
# Initialize the rotary encoder's SW pin on GPIO pin 22
button = Button(22)
last_rotary_value = 0 # Variable to store the last value of rotary encoder
while True: # Infinite loop to continuously monitor the encoder
current_rotary_value = encoder.steps # Read current step count from rotary encoder
# Check if the rotary encoder value has changed
if last_rotary_value != current_rotary_value:
print("Result =", current_rotary_value) # Print the current value
last_rotary_value = current_rotary_value # Update the last value
# Check if the rotary encoder is pressed
if button.is_pressed:
print("Button pressed!") # Print message on button press
button.wait_for_release() # Wait until button is released
sleep(0.1) # Short delay to prevent excessive CPU usage
print("Program terminated") # Print message when program is terminated via keyboard interrupt
Code Analysis
Importing Libraries
The script starts with importing the
RotaryEncoderandButtonclasses from gpiozero for interfacing with the rotary encode, respectively, and thesleepfunction from the time module for adding delays.from gpiozero import RotaryEncoder, Button from time import sleep
Initializing the Rotary Encoder and Button
This line initializes a
RotaryEncoderobject from thegpiozerolibrary. The encoder is connected to GPIO pins 17 and 27.The
wrap=Trueparameter means the encoder’s value will reset after reachingmax_steps(16 in this case), mimicking a circular dial behavior.Here, a
Buttonobject is created, connected to GPIO pin 22. This object will be used to detect when the rotary encoder is pressed.
encoder = RotaryEncoder(a=17, b=27, wrap=True, max_steps=16) button = Button(22)
Implementing the Monitoring Loop
An infinite loop (
while True:) is used to continuously monitor the rotary encoder.The current value of the rotary encoder is read and compared with its last recorded value. If there’s a change, the new value is printed.
The script checks if the rotary encoder is pressed. On detection of a press, it prints a message and waits until the rotary encoder is released.
A
sleep(0.1)is included to add a brief delay, preventing excessive CPU usage.
last_rotary_value = 0 try: while True: current_rotary_value = encoder.steps if last_rotary_value != current_rotary_value: print("Result =", current_rotary_value) last_rotary_value = current_rotary_value if button.is_pressed: print("Button pressed!") button.wait_for_release() sleep(0.1) except KeyboardInterrupt: print("Program terminated")
