Lesson 30: Relay Module
In this lesson, you will learn how to control a relay module using a Raspberry Pi. You’ll learn how to write a simple Python script to turn the relay on and off at one-second intervals. This project is a practical introduction to using GPIO pins for controlling external devices, providing a basic understanding of how relays work in electronic circuits. It’s a straightforward and informative exercise, well-suited for beginners starting with Raspberry Pi and hardware control.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
5V Relay Module
RGB LED Module
../_images/Lesson_30_Relay_Pi_bb.png
from time import sleep
# Replace with your GPIO pin number
relay_pin = 17  # Example using GPIO17
# Initialize relay object
relay = OutputDevice(relay_pin)
      # Turn on the relay
      relay.on()
      sleep(1)  # Relay remains on for 1 second
      # Turn off the relay
      relay.off()
      sleep(1)  # Relay remains off for 1 second
   # Capture Ctrl+C and safely close the program
   relay.off()
   print("Program interrupted by user")
Code Analysis
  1. Import Libraries
    Import the gpiozero library for GPIO control and the time library for delays.
  2. Initialize the Relay
    Define the GPIO pin connected to the relay and initialize an OutputDevice object with that pin.
  3. Relay Control in a Loop
    The while True: loop continuously toggles the relay. relay.on() and relay.off() are used to control the relay, and sleep(1) creates a one-second delay between each state.
            relay.on()
            relay.off()
  4. Exception Handling
    The except block captures a KeyboardInterrupt (Ctrl+C). It ensures the relay is turned off and the program exits safely.
        relay.off()
