Lesson 18: Temperature Sensor Module (DS18B20)
In this lesson, you will learn how to use a Raspberry Pi to read temperature data from a DS18B20 temperature sensor. You will understand how to locate the sensor’s device file, read and parse its raw data, and convert this data into Celsius and Fahrenheit readings.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
The DS18B20 module communicates with the Raspberry Pi using the onewire protocol. Before running the code, you need to enable the onewire function of the Raspberry Pi. You can refer to this tutorial: 1-Wire Configuration.
import glob
# Path to the directory containing device files for 1-wire devices
base_dir = "/sys/bus/w1/devices/"
# Finds the first device folder that starts with "28", specific to DS18B20
device_folder = glob.glob(base_dir + "28*")[0]
# Device file containing the temperature data
device_file = device_folder + "/w1_slave"
def read_temp_raw():
# Reads raw temperature data from the sensor
f = open(device_file, "r")
lines = f.readlines()
f.close()
return lines
def read_temp():
# Parses the raw temperature data and converts it to Celsius and Fahrenheit
lines = read_temp_raw()
# Waits for a valid temperature reading
while lines[0].strip()[-3:] != "YES":
time.sleep(0.2)
equals_pos = lines[1].find("t=")
if equals_pos != -1:
temp_string = lines[1][equals_pos + 2 :]
temp_c = float(temp_string) / 1000.0 # Convert to Celsius
temp_f = temp_c * 9.0 / 5.0 + 32.0 # Convert to Fahrenheit
return temp_c, temp_f
# Main loop to continuously read and print temperature
temp_c, temp_f = read_temp()
formatted_output = f"Temperature: {temp_c:.2f}°C / {temp_f:.2f}°F"
print(formatted_output)
time.sleep(1) # Wait for 1 second between readings
# Gracefully exit the program on CTRL+C
print("Exit")
Code Analysis
Importing Necessary Libraries
The
globlibrary is used to search for the temperature sensor’s device folder. Thetimelibrary is used for implementing delays in the program.import glob import time
Locating the Temperature Sensor Device File
The code searches for the directory of the DS18B20 sensor by looking for a folder name starting with “28”. The device file
w1_slavecontains the temperature data.base_dir = "/sys/bus/w1/devices/" device_folder = glob.glob(base_dir + "28*")[0] device_file = device_folder + "/w1_slave"
Reading Raw Temperature Data
This function opens the device file and reads its content. It returns the raw temperature data as a list of strings.
def read_temp_raw(): f = open(device_file, "r") lines = f.readlines() f.close() return lines
Parsing and Converting Temperature Data
The
read_tempfunction callsread_temp_rawto get the raw data. It waits for a valid temperature reading and then extracts, parses, and converts the temperature to Celsius and Fahrenheit.def read_temp(): lines = read_temp_raw() while lines[0].strip()[-3:] != "YES": time.sleep(0.2) lines = read_temp_raw() equals_pos = lines[1].find("t=") if equals_pos != -1: temp_string = lines[1][equals_pos + 2 :] temp_c = float(temp_string) / 1000.0 temp_f = temp_c * 9.0 / 5.0 + 32.0 return temp_c, temp_f
Main Program Loop and Graceful Exit
The
tryblock contains an infinite loop to continuously read and display the temperature. Theexceptblock catches a KeyboardInterrupt to exit the program gracefully.try: while True: temp_c, temp_f = read_temp() formatted_output = f"Temperature: {temp_c:.2f}°C / {temp_f:.2f}°F" print(formatted_output) time.sleep(1) except KeyboardInterrupt: print("Exit")
