Lesson 19: Temperature and Humidity Sensor Module (DHT11)
In this lesson, you will learn how to connect and read data from a DHT11 temperature and humidity sensor using a Raspberry Pi. You will learn how to set up the sensor, read temperature in both Celsius and Fahrenheit, and obtain humidity readings. This project introduces you to working with external sensors, handling real-time data, and basic exception handling in Python.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
The kit may contain different versions of the DHT11 module. Please confirm the wiring method according to the module you have.0
../_images/Lesson_19_dht11_module_pi_bb_bb.png ../_images/Lesson_19_dht11_module_pi_new_bb.png
Install Library
The adafruit-circuitpython-dht library relies on Blinka, so please ensure that Blinka has been installed. To install libraries, refer to Insatll Adafruit_Blinka (CircuitPython) - Optional.
Before installing the library, please make sure that the virtual Python environment is activated:
source ~/env/bin/activate
Install adafruit-circuitpython-dht library:
pip install adafruit-circuitpython-dht
  • Please ensure that you have installed the Python library required for running the code according to the “Install Library” steps.
  • Before running the code, please make sure that you have activated the virtual Python environment with blinka installed. You can activate the virtual environment using a command like this:
  • Find the code for this lesson in universal-maker-sensor-kit-main/pi/ directory, or directly copy and paste the code below. Execute the code by running the following commands in terminal:
    python 19_dht11_module.py
import board
import adafruit_dht
# Initial the dht device, with data pin connected to:
dhtDevice = adafruit_dht.DHT11(board.D17)
        # Print the values to the serial port
        temperature_c = dhtDevice.temperature
        temperature_f = temperature_c * (9 / 5) + 32
        humidity = dhtDevice.humidity
        print(
            "Temp: {:.1f} F / {:.1f} C    Humidity: {}% ".format(
                temperature_f, temperature_c, humidity
    except RuntimeError as error:
        # Errors happen fairly often, DHT's are hard to read, just keep going
        print(error.args[0])
        time.sleep(2.0)
        continue
    except Exception as error:
        dhtDevice.exit()
        raise error
    time.sleep(2.0)
Code Analysis
  1. Importing Libraries:
    The code begins by importing necessary libraries. time for handling delays, board for accessing Raspberry Pi GPIO pins, and adafruit_dht for interacting with the DHT11 sensor. For more detail about the adafruit_dht library, please refer to adafruit/Adafruit_CircuitPython_DHT.
    import board
    import adafruit_dht
  2. Initializing the Sensor:
    The DHT11 sensor is initialized with the data pin connected to GPIO 17 of the Raspberry Pi. This setup is crucial for the sensor to communicate with the Raspberry Pi.
  3. Reading Sensor Data in a Loop:
    The while True loop allows the program to continuously check the sensor for new data.
  4. Try-Except Blocks:
    Within the loop, a try-except block is used to handle potential runtime errors. Reading from DHT sensors can often result in errors due to timing issues or sensor quirks.
        # Sensor data reading code here
        # Handling common sensor reading errors
        time.sleep(2.0)
        continue
        # Handling other exceptions and exiting
        dhtDevice.exit()
        raise error
  5. Reading and Printing Sensor Data:
    The temperature and humidity are read from the sensor and converted into human-readable formats. The temperature is also converted from Celsius to Fahrenheit.
    print("Temp: {:.1f} F / {:.1f} C    Humidity: {}% ".format(temperature_f, temperature_c, humidity))
  6. Handling Read Errors:
    The DHT11 sensor can often return errors, so the code uses a try-except block to handle these. If an error occurs, the program waits for 2 seconds before attempting to read from the sensor again.
        time.sleep(2.0)
        continue
  7. General Exception Handling:
    Any other exceptions that might occur are handled by safely exiting the sensor and re-raising the error. This ensures the program doesn’t continue in an unstable state.
        dhtDevice.exit()
        raise error
  8. Delay Between Readings:
    A 2-second delay is added at the end of the loop to avoid constant polling of the sensor, which can lead to erroneous readings.
    time.sleep(2.0)
