Lesson 32: Passive Buzzer Module
In this lesson, you will learn how to create musical tones using a TonalBuzzer with a Raspberry Pi. You’ll learn how to program the Raspberry Pi to play a sequence of musical notes using Python. The lesson includes defining a tune as a list of notes and durations, and writing a function to play these notes through the buzzer. This project offers a straightforward introduction to working with sound output and Python programming, making it a practical choice for beginners interested in exploring musical applications with the Raspberry Pi.
ITEMS IN THIS KIT
Universal Maker Sensor Kit
94
Component Introduction
Purchase Link
Raspberry Pi 5
../_images/Lesson_32_Passive_buzzer_Pi_bb.png
from gpiozero import TonalBuzzer
from time import sleep
# Initialize the TonalBuzzer on GPIO pin 17
tb = TonalBuzzer(17)  # Change to the pin number your buzzer is connected to
def play(tune):
   Play a musical tune using the buzzer.
   :param tune: List of tuples, where each tuple contains a note and its duration.
   for note, duration in tune:
      print(note)  # Print the current note being played
      tb.play(note)  # Play the note on the buzzer
      sleep(float(duration))  # Wait for the duration of the note
   tb.stop()  # Stop the buzzer after playing the tune
# Define the musical tune as a list of notes and their durations
tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2),
   ('Eb4', 0.2), ('E4', 0.2), (None, 0.6),
   ('F#4', 0.2), ('G4', 0.2), (None, 0.6),
   ('Eb4', 0.2), ('E4', 0.2), (None, 0.2),
   ('F#4', 0.2), ('G4', 0.2), (None, 0.2),
   ('C4', 0.2), ('B4', 0.2), (None, 0.2),
   ('B4', 0.2), ('Bb4', 0.5), (None, 0.6),
   ('A4', 0.2), ('G4', 0.2), ('E4', 0.2),
   ('D4', 0.2), ('E4', 0.2)]
# Play the tune
play(tune)
Code Analysis
  1. Import Libraries
    Import TonalBuzzer from gpiozero for sound generation and sleep from time for timing control.
  2. Initialize the TonalBuzzer
    Create a TonalBuzzer object connected to GPIO pin 17.
  3. Define the Play Function
    The play function takes a list of tuples as input, where each tuple represents a musical note and its duration. It iterates through each tuple, playing the note and waiting for its duration.
    def play(tune):
            print(note)
            tb.play(note)
        tb.stop()
  4. Define the Musical Tune
    The tune is defined as a list of tuples. Each tuple contains a note and its duration in seconds. None is used to represent a pause.
    tune = [('C#4', 0.2), ('D4', 0.2), (None, 0.2), ...]
  5. Play the Tune
    The play function is called with the tune list, causing the buzzer to play the defined sequence of notes.
    play(tune)
