Lesson 33: Servo Motor (SG90)
In this lesson, you will learn how to control a servo motor using a Raspberry Pi. You’ll learn how to adjust the servo’s pulse width settings for precise control and write a Python script to move the servo to different positions: minimum, middle, and maximum.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import Servo
from time import sleep
# GPIO pin for the servo
myGPIO = 17
# Correction factor for the servo
myCorrection = 0.45
maxPW = (2.0 + myCorrection) / 1000 # Maximum pulse width
minPW = (1.0 - myCorrection) / 1000 # Minimum pulse width
# Initialize the servo with adjusted pulse width range
servo = Servo(myGPIO, min_pulse_width=minPW, max_pulse_width=maxPW)
# Continuously move servo between positions
# Move servo to middle position
servo.mid()
print("mid")
sleep(0.5)
# Move servo to minimum position
servo.min()
print("min")
sleep(1)
servo.mid()
print("mid")
sleep(0.5)
# Move servo to maximum position
servo.max()
print("max")
sleep(1)
Code Analysis
Import Libraries
Import the
Servoclass fromgpiozerofor servo control andsleepfromtimefor timing.from gpiozero import Servo from time import sleep
GPIO Pin and Servo Correction Factor
Define the GPIO pin connected to the servo and set a correction factor to calibrate the servo’s pulse width range.
myGPIO = 17 myCorrection = 0.45 maxPW = (2.0 + myCorrection) / 1000 minPW = (1.0 - myCorrection) / 1000
Initialize the Servo
Create a
Servoobject with the specified GPIO pin and adjusted pulse width range.servo = Servo(myGPIO, min_pulse_width=minPW, max_pulse_width=maxPW)
Move the Servo Continuously
Use a
while Trueloop to move the servo between its minimum, middle, and maximum positions, printing the current position and pausing between movements.while True: servo.mid() print("mid") sleep(0.5) servo.min() print("min") sleep(1) servo.mid() print("mid") sleep(0.5) servo.max() print("max") sleep(1)
