Lesson 29: Traffic Light Module
In this lesson, you will learn to simulate traffic lights using a Raspberry Pi. You’ll program the Raspberry Pi to control these LEDs in a sequence that resembles traffic lights: the red LED will be active for 3 seconds, the yellow LED will blink in a specific pattern, and then the green LED will turn on for 3 seconds. This project is a practical way to get started with GPIO interfacing and Python programming, suitable for those new to combining hardware and software with the Raspberry Pi.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from gpiozero import LED
from time import sleep
# Initialize LED pins
red = LED(22) # Red LED connected to GPIO pin 22
yellow = LED(27) # Yellow LED connected to GPIO pin 27
green = LED(17) # Green LED connected to GPIO pin 17
# LED control in a continuous loop
# Red LED cycle
red.on() # Turn on red LED
sleep(3) # Red LED on for 3 seconds
red.off() # Turn off red LED
# Yellow LED blinking pattern
yellow.on() # Turn on yellow LED
sleep(0.5) # Yellow LED on for 0.5 second
yellow.off() # Turn off yellow LED
sleep(0.5) # Off for 0.5 second
yellow.on() # Repeat blinking
# Green LED cycle
green.on() # Turn on green LED
sleep(3) # Green LED on for 3 seconds
green.off() # Turn off green LED
# Turn off all LEDs and exit safely on keyboard interrupt
red.off()
yellow.off()
green.off()
Code Analysis
Import Libraries
The
gpiozerolibrary is imported to control the GPIO pins, and thetimelibrary’ssleepfunction is used for timing delays.from gpiozero import LED from time import sleep
Initialize LED pins
Here, each LED is associated with a specific GPIO pin on the Raspberry Pi using the
LEDclass from thegpiozerolibrary.red = LED(22) # Red LED connected to GPIO pin 22 yellow = LED(27) # Yellow LED connected to GPIO pin 27 green = LED(17) # Green LED connected to GPIO pin 17
LED Control Loop
The
while True:loop runs continuously, cycling through each LED. It turns each LED on and off in a specific pattern, usingon(),off(), andsleep()functions.Red LED is turned on for 3 seconds.
Yellow LED blinks: 0.5 seconds on, 0.5 seconds off, repeated three times.
Green LED is turned on for 3 seconds.
try: while True: # Red LED cycle red.on() sleep(3) red.off() # Yellow LED blinking pattern # [The pattern is repeated three times] # Green LED cycle green.on() sleep(3) green.off()
Exception Handling
The
exceptblock catches aKeyboardInterrupt(usually generated by pressing Ctrl+C). It ensures all LEDs are turned off before the program exits, preventing the LEDs from being left in an undefined state.except KeyboardInterrupt: red.off() yellow.off() green.off()
