What Do We Need?
Raspberry Pi
The Raspberry Pi is a low cost, credit-card sized computer that plugs into a computer monitor or TV and used with a standard keyboard and mouse. It’s a versatile device that allows people of all ages to explore computing and learn programming languages such as Scratch and Python.
Power Adapter
Model |
Recommended power supply (voltage/current) |
Raspberry Pi 5 |
5V/5A, 5V/3A limits peripherals to 600mA |
Raspberry Pi 4 Model B |
5V/3A |
Raspberry Pi 3 (all models) |
5V/2.5A |
Micro SD Card
Your Raspberry Pi needs an Micro SD card to store all its files and the Raspberry Pi OS. You will need a micro SD card with a capacity of at least 8 GB.
Optional Components
Screen
To access the Raspberry Pi’s desktop environment, you can connect it to a TV or computer monitor. If the screen includes speakers, audio will be output through them.
Mouse & Keyboard
When you use a screen, a USB keyboard and a USB mouse are also needed.
HDMI
The Raspberry Pi has HDMI (or Micro HDMI) output ports, which are compatible with the HDMI ports of most modern TVs and computer monitors. If your screen only comes with a DVI or VGA port, you will need to use the corresponding adapter cable.
Case
You can place the Raspberry Pi in a case to protect your device. On our official website, we offer related products for sale; you can view or purchase Raspberry Pi cases here.
Sound or Earphone
Most Raspberry Pi models come with a 3.5mm audio port, which can be used when your screen doesn’t have built-in speakers or isn’t in use. However, it’s important to note that the latest Raspberry Pi 5 doesn’t come with a 3.5mm audio port.
