Lesson 26: I2C LCD 1602
In this lesson, you will learn the basics of displaying text on an LCD screen using a Raspberry Pi. We’ll start by showing you how to connect a standard LCD to the Raspberry Pi using the I2C interface. You’ll learn how to set up the LCD with simple parameters like the Raspberry Pi model and I2C address. Then, we’ll walk you through writing a basic Python script to display messages like “Hello World!” on the screen. This straightforward project is aimed at beginners, offering a foundational introduction to interfacing hardware with the Raspberry Pi and basic Python programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi 5 |
from LCD import LCD
# Initialize the LCD with specific parameters: Raspberry Pi revision, I2C address, and backlight status
lcd = LCD(2, 0x27, True) # Using Raspberry Pi revision 2, I2C address 0x27, backlight enabled
# Display messages on the LCD
lcd.message("Hello World!", 1) # Display 'Hello World!' on line 1
lcd.message(" - Sunfounder", 2) # Display ' - Sunfounder' on line 2
# Keep the messages displayed for 5 seconds
time.sleep(5)
# Clear the LCD display
lcd.clear()
Code Analysis
Import Libraries
Import the
timemodule for creating delays and theLCDmodule for controlling the LCD.For more detail about the
LCDlibrary, please refer to sterlingbeason/LCD-1602-I2C.import time from LCD import LCD
Initialize the LCD
Create an
LCDobject with specific parameters: the Raspberry Pi revision, the I2C address of the LCD, and the backlight status. In this case, Raspberry Pi revision 2(and higher version), I2C address 0x27, and backlight enabled.lcd = LCD(2, 0x27, True)
Display Messages on the LCD
Use the
messagemethod of theLCDobject to display text on the LCD. The first argument is the text, and the second argument is the line number.lcd.message("Hello World!", 1) lcd.message(" - Sunfounder", 2)
Keep the Messages Displayed
Pause the program for 5 seconds, keeping the messages on the LCD during this time.
time.sleep(5)
Clear the LCD Display
After the delay, clear the display using the
clearmethod of theLCDobject.lcd.clear()
