Touch Sensor Module
../_images/22_touch_sensor_moudle.png
The Touch switch sensor (also called touch button or touch switch) is widely used to control devices (e.g. touchable lamp). It has the same functionality as a button. It is used instead of the button on many new devices because it makes the product look neat.
Pinout
  • VCC: This is the positive power supply input from the main control.
  • GND: Ground connection.
  • IO: Digital output. High level with a touch, low level without touching.
Principle
This module is a capacitive touch switch module based on a touch sensor IC (TTP223B). In the normal state, the module outputs a low level with low power consumption; when a finger touches the corresponding position, the module outputs a high level and becomes low level again after the finger is released.
Here is how the capacitive touch switch works:
A capacitive touch switch has different layers—top insulating face plate followed by touch plate, another insulating layer and then ground plate.
../_images/22_touch_sensor_moudle_principle.jpeg
In practice, a capacitive sensor can be made on a double-sided PCB by regarding one side as the touch sensor and the opposite side as ground plate of the capacitor. When power is applied across these plates, the two plates get charged. In equilibrium state, the plates have the same voltage as the power source.
The touch detector circuit has an oscillator whose frequency is dependent on capacitance of the touchpad. When a finger is moved close to the touchpad, additional capacitance causes frequency of this internal oscillator to change. The detector circuit tracks oscillator frequency at timed intervals, and when the shift crosses the threshold change, the circuit triggers a key-press event.
Schematic diagram
../_images/22_touch_sensor_moudle_schematic.png
Example
