Lesson 34: TT Motor
In this lesson, you will learn how to operate a TT motor using the Raspberry Pi Pico W and an L9110 motor control board. We’ll guide you through the process of configuring two PWM (Pulse Width Modulation) pins to control the motor. You’ll set up the motor to run for 5 seconds and then turn off. This practical exercise offers a valuable opportunity to delve into motor control mechanisms and PWM signals, crucial in microcontroller programming.
Universal Maker Sensor Kit |
94 |
Component Introduction |
Purchase Link |
Raspberry Pi Pico W |
from machine import Pin, PWM
motor_a = PWM(Pin(26), freq=1000)
motor_b = PWM(Pin(27), freq=1000)
# turn on motor
motor_a.duty_u16(0)
motor_b.duty_u16(65535) # speed(0-65535)
time.sleep(5)
# turn off motor
motor_a.duty_u16(0)
motor_b.duty_u16(0)
Code Analysis
Importing Libraries
The
machinemodule is imported to interact with the GPIO pins and PWM functionalities of the Raspberry Pi Pico W.The
timemodule is used for creating delays in the code.
from machine import Pin, PWM import time
Initializing PWM Objects
Two PWM objects,
motor_aandmotor_b, are created. They correspond to GPIO pins 26 and 27, respectively.The frequency for PWM is set to 1000 Hz, a common frequency for motor control.
motor_a = PWM(Pin(26), freq=1000) motor_b = PWM(Pin(27), freq=1000)
Turning on the Motor
motor_a.duty_u16(0)sets the duty cycle ofmotor_apin to 0, whilemotor_b.duty_u16(65535)sets the duty cycle ofmotor_bpin to 65535, running the motor at full speed. For more details, please refer to the working principle of L9110.The motor runs for 5 seconds, controlled by
time.sleep(5).
# turn on motor motor_a.duty_u16(0) motor_b.duty_u16(65535) # speed(0-65535) time.sleep(5)
Turning off the Motor
Both
motor_aandmotor_bare set to a duty cycle of 0, stopping the motor.# turn off motor motor_a.duty_u16(0) motor_b.duty_u16(0)
