PCF8591 ADC DAC Converter Module
The PCF8591 is a single-chip, single-supply low-power 8-bit CMOS data acquisition device with four analog inputs, one analog output and a serial I2C-bus interface. Three address pins A0, A1 and A2 are used for programming the hardware address, allowing the use of up to eight devices connected to the I2C-bus without additional hardware. Address, control and data to and from the device are transferred serially via the two-line bidirectional I2C-bus.
The functions of the device include analog input multiplexing, on-chip track and hold function, 8-bit analog-to-digital conversion and an 8-bit digital-to-analog conversion. The maximum conversion rate is given by the maximum speed of the I2C-bus.
Principle
Addressing:
Each PCF8591 device in an I2C-bus system is activated by sending a valid address to the device. The address consists of a fixed part and a programmable part. The programmable part must be set according to the address pins A0, A1 and A2. The address always has to be sent as the first byte after the start condition in the I2C-bus protocol. The last bit of the address byte is the read/write-bit which sets the direction of the following data transfer (see as below).
Control byte:
The second byte sent to a PCF8591 device will be stored in its control register and is required to control the device function. The upper nibble of the control register is used for enabling the analog output, and for programming the analog inputs as single-ended or differential inputs. The lower nibble selects one of the analog input channels defined by the upper nibble. If the auto-increment flag is set, the channel number is incremented automatically after each A/D conversion. See the figure below.
Schematic diagram
Example
Lesson 10: PCF8591 ADC DAC Converter Module (Arduino UNO)
Lesson 10: PCF8591 ADC DAC Converter Module (Raspberry Pi Pico)
Lesson 10: PCF8591 ADC DAC Converter Module (Raspberry Pi)
Lesson 02: Capacitive Soil Moisture Module (Raspberry Pi)
Lesson 09: Joystick Module (Raspberry Pi)
Lesson 11: Photoresistor Module (Raspberry Pi)
Lesson 13: Potentiometer Module (Raspberry Pi)
Lesson 25: Water Level Sensor Module (Raspberry Pi)
