IR Obstacle Avoidance Sensor Module
This module can adapt to ambient light and includes a pair of infrared emitting and receiving tubes. The emitting tube sends out infrared at a specific frequency, and when the detection direction encounters an obstacle (reflective surface), the receiving tube picks up the reflected infrared. After being processed by the comparator circuit, the green indicator light will turn on, and simultaneously, the signal output interface will produce a digital signal (a low level signal). The detection distance can be adjusted using a potentiometer knob.
Specification
Supply Voltage: 3.3V - 5V
PCB Size: 32 x 14mm
Output Signal Type: Digital Output
Detection Angle: 35°
Detection distance: 2~30cm
Pinout
VCC: This is the positive power supply input from the main control.
GND: Ground connection.
OUT: Digital output. Outputs high level when there is no obstacle, and outputs low level when an obstacle is detected. The detection distance of obstacles can be adjusted by the potentiometer on the module.
Principle
An obstacle avoidance sensor mainly consists of an infrared transmitter, an infrared receiver and a potentiometer. According to the reflecting character of an object, if there is no obstacle, the emitted infrared ray will weaken with the distance it spreads and finally disappear. If there is an obstacle, when the infrared ray encounters it, the ray will be reflected back to the infrared receiver. Then the infrared receiver detects this signal and confirms an obstacle in front. The detection range can be adjusted by the built-in potentiometer.
Schematic diagram
Example
Lesson 08: IR Obstacle Avoidance Sensor Module (Arduino UNO)
Lesson 08: IR Obstacle Avoidance Sensor Module (Raspberry Pi Pico)
Lesson 08: IR Obstacle Avoidance Sensor Module (Raspberry Pi)
Lesson 39: Automatic soap dispenser (Arduino UNO)
