Lesson 9 IR Receiver Module¶
An infrared-receiver (as shown below) is a component which receives infrared signals and can independently receive infrared rays and output signals compatible with TTL level. It is similar with a normal plastic-packaged transistor in size and is suitable for all kinds of infrared remote control and infrared transmission.
1 * Raspberry Pi
1 * Breadboard
1 * IR receiver module
1 * IR Remote Controller
1 * 3-Pin anti-reverse cable
Experimental Principle
In this experiment, send signals to IR receiver by pressing buttons on the IR remote controller. The counter will add 1 every time it receives signals; in other words, the increased number indicates IR signals are received.
The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
IR Receiver Module |
GPIO0 |
GPIO17 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/09_ir_receiver/
Step 3: Compile.
gcc ir_receiver.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define IR 0
int cnt = 0;
void myISR(void)
printf("Received infrared. cnt = %d\n", ++cnt);
int main(void)
if(wiringPiISR(IR, INT_EDGE_FALLING, &myISR) == -1){
printf("setup ISR failed !");
//pinMode(IR, INPUT);
while(1);
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 09_ir_receiver.py
import RPi.GPIO as GPIO
IrPin = 11
count = 0
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(IrPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
def cnt(ev=None):
global count
count += 1
print ('Received infrared. cnt = ', count)
def loop():
GPIO.add_event_detect(IrPin, GPIO.FALLING, callback=cnt) # wait for falling
pass # Don't do anything
def destroy():
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Press any key of the remote. Then you can see the LED on the module blinking, and “Received infrared. cnt = xxx” printed on the screen. “xxx” means the time you pressed the key(s).
