Lesson 7 Tilt-Switch Module¶
The tilt-switch module (as shown below) in this kit is a ball tilt-switch with a metal ball inside. It is used to detect inclinations of a small angle.
1 * Raspberry Pi
1 * Breadboard
1 * Dual-color LED module
1 * Tilt-switch module
2 * 3-Pin anti-reverse cable
Experimental Principle
The principle is very simple. The ball in the tilt-switch changes with different angle of inclination to trigger the circuit. When the ball in tilt switch runs from one end to the other end due to shaking caused by external force, the tilt switch will conduct and the LED will emit red light, otherwise it will break and the LED will emit green light.
The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
Tilt Switch Module |
GPIO0 |
GPIO17 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Raspberry Pi |
Dual-Color LED Module |
GPIO1 |
GPIO18 |
R |
GND |
GND |
GND |
GPIO2 |
GPIO27 |
G |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/07_tilt_switch/
Step 3: Compile.
gcc tilt_switch.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define TiltPin 0
#define Gpin 2
#define Rpin 1
void LED(char* color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == "RED")
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == "GREEN")
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
else
printf("LED Error");
int main(void)
pinMode(TiltPin, INPUT);
LED("GREEN");
if(0 == digitalRead(TiltPin)){
delay(10);
LED("RED");
printf("Tilt!\n");
else if(1 == digitalRead(TiltPin)){
delay(10);
while(!digitalRead(TiltPin));
LED("GREEN");
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 07_tilt_switch.py
import RPi.GPIO as GPIO
TiltPin = 11
Gpin = 13
Rpin = 12
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(Gpin, GPIO.OUT) # Set Green Led Pin mode to output
GPIO.setup(Rpin, GPIO.OUT) # Set Red Led Pin mode to output
GPIO.setup(TiltPin, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Set BtnPin's mode is input, and pull up to high level(3.3V)
GPIO.add_event_detect(TiltPin, GPIO.BOTH, callback=detect, bouncetime=200)
def Led(x):
if x == 0:
GPIO.output(Rpin, 1)
GPIO.output(Gpin, 0)
if x == 1:
GPIO.output(Rpin, 0)
GPIO.output(Gpin, 1)
def detect(chn):
Led(GPIO.input(TiltPin))
def loop():
def destroy():
GPIO.output(Gpin, GPIO.HIGH) # Green led off
GPIO.output(Rpin, GPIO.HIGH) # Red led off
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Place the tilt switch module horizontally, and the LED will flash green. If you tilt it, “Tilt!” will be printed on the screen and the LED will change to red. Place it horizontally again, and the LED will flash green again.
