Lesson 20 Photoresistor Module¶
A photoresistor is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity.
1 * Raspberry Pi
1 * Breadboard
1 * PCF8591
1 * Photoresistor module
1 * 3-Pin anti-reverse cable
Several Jumper wires
Experimental Principle
With light intensity increasing, the resistance of a photoresistor will decrease. Thus the output voltage changes. Analog signals collected by the photoresistor are converted to digital signals through PCF8591. Then these digital signals are transmitted to Raspberry Pi and printed on the screen. The schematic diagram:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
PCF8591 Module |
SDA |
SDA1 |
SDA |
SCL |
SCL1 |
SCL |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Photoresistor |
PCF8591 Module |
SIG |
AIN0 |
VCC |
3V3 |
VCC |
GND |
GND |
GND |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/20_photoresistor/
Step 3: Compile.
gcc photoresistor.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <stdio.h>
#include <wiringPi.h>
#include <pcf8591.h>
#include <math.h>
#define PCF 120
#define DOpin 0
int main()
int analogVal;
if(wiringPiSetup() == -1){
// Setup pcf8591 on base pin 120, and address 0x48
pcf8591Setup(PCF, 0x48);
while(1) // loop forever
analogVal = analogRead(PCF + 0);
printf("Value: %d\n", analogVal);
delay (200);
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 20_photoresistor.py
import PCF8591 as ADC
import RPi.GPIO as GPIO
DO = 17
GPIO.setmode(GPIO.BCM)
def setup():
ADC.setup(0x48)
GPIO.setup(DO, GPIO.IN)
def loop():
status = 1
print ('Value: ', ADC.read(0))
time.sleep(0.2)
if __name__ == '__main__':
setup()
loop()
Now, change light intensity (e.g. cover the module with a pad), and the value printed on the screen will change accordingly.
