Lesson 3 7-Color Auto-flash LED
On the 7-Color Auto-flash LED module, the LED can automatically flash built-in colors after power on. It can be used to make quite fascinating light effects.
_images/image106.png
  • 1 * Raspberry Pi
  • 1 * Breadboard
  • 1 * 7-color auto-flash LED module
  • 1 * 3-Pin anti-reverse cable
Experimental Principle
When it is power on, the 7-color auto-flash LED will flash built-in colors.
The schematic diagram of the module is as shown below:
_images/image107.png
Experimental Procedures
Build the circuit.
Raspberry Pi
GPIO Extension Board
Auto-flash LED Module
GND
GND
GND
3.3V
3V3
VCC
_images/image108.png
There are two “GND” pins on the module. You only need to connect one of them.
Now, you will see 7-color auto-flash LED flashing seven colors.
_images/image109.jpeg
