Lesson 15 Joystick PS2¶
There are five operation directions for joystick PS2: up, down, left, right and press-down.
1 * Raspberry Pi
1 * Breadboard
1 * PCF8591
1 * Joystick PS2 module
1 * 5-Pin anti-reverse cable
Several Jumper wires
Experimental Principle
This module has two analog outputs (corresponding to X and Y coordinates) and one digital output representing whether it is pressed on Z axis.
In this experiment, we connect pin X and Y to the analog input ports of the A/D convertor so as to convert analog quantities into digital ones. Then program on Raspberry Pi to detect the moving direction of the Joystick. The schematic diagram:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
PCF8591 Module |
SDA |
SDA1 |
SDA |
SCL |
SCL1 |
SCL |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Joystick PS2 |
PCF8591 Module |
Y |
AIN0 |
X |
AIN1 |
Bt |
AIN2 |
VCC |
3V3 |
VCC |
GND |
GND |
GND |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/15_joystick_PS2/
Step 3: Compile.
gcc joystick_PS2.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <stdio.h>
#include <wiringPi.h>
#include <pcf8591.h>
#define PCF 120
#define uchar unsigned char
int AIN0 = PCF + 0;
int AIN1 = PCF + 1;
int AIN2 = PCF + 2;
char *state[7] = {"home", "up", "down", "left", "right", "pressed"};
int direction(){
int x, y, b;
int tmp=0;
x = analogRead(AIN1);
y = analogRead(AIN0);
b = analogRead(AIN2);
if (y <= 30)
tmp = 1; // up
if (y >= 225)
tmp = 2; // down
if (x >= 225)
tmp = 3; // left
if (x <= 30)
tmp = 4; // right
if (b <= 30)
tmp = 5; // button preesd
if (x-125<15 && x-125>-15 && y-125<15 && y-125>-15 && b >= 60)
tmp = 0; // home position
return tmp;
int main (void)
int tmp=0;
int status = 0;
wiringPiSetup ();
// Setup pcf8591 on base pin 120, and address 0x48
pcf8591Setup (PCF, 0x48);
while(1) // loop forever
tmp = direction();
if (tmp != status)
printf("%s\n", state[tmp]);
status = tmp;
return 0 ;
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 15_joystick_PS2.py
import PCF8591 as ADC
def setup():
ADC.setup(0x48) # Setup PCF8591
global state
def direction(): #get joystick result
state = ['home', 'up', 'down', 'left', 'right', 'pressed']
i = 0
if ADC.read(0) <= 30:
i = 1 #up
if ADC.read(0) >= 225:
i = 2 #down
if ADC.read(1) >= 225:
i = 3 #left
if ADC.read(1) <= 30:
i = 4 #right
if ADC.read(2) <= 30:
i = 5 # Button pressed
if ADC.read(0) - 125 < 15 and ADC.read(0) - 125 > -15 and ADC.read(1) - 125 < 15 and ADC.read(1) - 125 > -15 and ADC.read(2) == 255:
i = 0
return state[i]
def loop():
status = ''
tmp = direction()
if tmp != None and tmp != status:
print (tmp)
status = tmp
def destroy():
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Now push the rocker upwards, and a string “up” will be printed on the screen; push it downwards, and “down” will be printed; if you push it left, “Left” will be printed on; If you push it right, and “Right” will be printed; If you press down the cap, “Button Pressed” will be printed on the screen.
