Lesson 6 Button Module¶
In this lesson, we will use button module to control a dual-color LED module.
1 * Raspberry Pi
1 * Breadboard
Several Jumper wires
1 * Button module
1 * Dual-color LED module
2 * 3-Pin anti-reverse cable
Experimental Principle
Use a normally open button as an input device of Raspberry Pi. When the button is pressed, the General Purpose Input/Output (GPIO) connected to the button will change to low level (0V). You can detect the state of the GPIO through programming. That is, if the GPIO turns into low level, it means the button is pressed, so you can run the corresponding code. In this experiment, we will print a string on the screen and control an LED.
The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
Button Module |
GPIO0 |
GPIO17 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Raspberry Pi |
Dual-Color LED Module |
GPIO1 |
GPIO18 |
R |
GND |
GND |
GND |
GPIO2 |
GPIO27 |
G |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/06_button/
Step 3: Compile.
gcc button.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define BtnPin 0
#define Gpin 1
#define Rpin 2
void LED(char* color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == "RED")
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == "GREEN")
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
else
printf("LED Error");
int main(void)
pinMode(BtnPin, INPUT);
LED("GREEN");
if(0 == digitalRead(BtnPin)){
delay(10);
LED("RED");
printf("Button is pressed\n");
else if(1 == digitalRead(BtnPin)){
delay(10);
while(!digitalRead(BtnPin));
LED("GREEN");
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 06_button.py
import RPi.GPIO as GPIO
BtnPin = 11
Gpin = 12
Rpin = 13
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(Gpin, GPIO.OUT) # Set Green Led Pin mode to output
GPIO.setup(Rpin, GPIO.OUT) # Set Red Led Pin mode to output
GPIO.setup(BtnPin, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Set BtnPin's mode is input, and pull up to high level(3.3V)
GPIO.add_event_detect(BtnPin, GPIO.BOTH, callback=detect, bouncetime=200)
def Led(x):
if x == 0:
GPIO.output(Rpin, 1)
GPIO.output(Gpin, 0)
if x == 1:
GPIO.output(Rpin, 0)
GPIO.output(Gpin, 1)
def detect(chn):
Led(GPIO.input(BtnPin))
def loop():
def destroy():
GPIO.output(Gpin, GPIO.HIGH) # Green led off
GPIO.output(Rpin, GPIO.HIGH) # Red led off
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
The LED on the module will emit green light. If you press the button, “Button pressed” will be printed on the screen and the LED will emit red light. If you release the button, “Button released” will be printed on the screen and the LED will flash green again.
