Lesson 29 IR Obstacle Avoidance Module¶
An IR obstacle avoidance module (as shown below) is used in this Lesson.
1 * Raspberry Pi
1 * Breadboard
1 * IR Obstacle module
1 * 3-Pin anti-reverse cable
Experimental Principle
An obstacle avoidance sensor mainly consists of an infrared-transmitter, an infrared-receiver and a potentiometer. According to the reflecting feature of an object, if there is no obstacle, emitted infrared ray will weaken with the propagation distance and finally disappear. If there is an obstacle, when infrared ray encounters an obstacle, it will be reflected back to the infrared-receiver. Then the infrared-receiver detects this signal and confirms an obstacle exists ahead.
The detection distance of the infrared sensor is adjustable - you may adjust it by the potentiometer.
The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/29_ir_obstacle/
Step 3: Compile.
gcc ir_obstacle.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define ObstaclePin 0
void myISR(void)
printf("Detected Barrier !\n");
int main(void)
printf("setup wiringPi failed !\n");
if(wiringPiISR(ObstaclePin, INT_EDGE_FALLING, &myISR) < 0){
printf("Unable to setup ISR !!!\n");
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 29_ir_obstacle.py
import RPi.GPIO as GPIO
ObstaclePin = 11
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(ObstaclePin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
def loop():
if (0 == GPIO.input(ObstaclePin)):
print ("Detected Barrier!")
def destroy():
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Now, if there is an obstacle ahead, a string “Detected Barrier!” will be printed on the screen.
