Lesson 34 Tracking Sensor¶
The infrared tracking sensor uses a TRT5000 sensor. The blue LED of TRT5000 is the emission tube and after electrified it emits infrared light invisible to human eye. The black part of the sensor is for receiving; the resistance of the resistor inside changes with the infrared light received.
1 * Raspberry Pi
1 * Breadboard
1 * Tracking sensor module
1 * 3-Pin anti-reverse cable
Experimental Principle
When the infrared transmitter emits rays to a piece of paper, if the rays shine on a white surface, they will be reflected and received by the receiver, and pin SIG will output low level; If the rays encounter black lines, they will be absorbed, thus the receiver gets nothing, and pin SIG will output high level. The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
Tracking Sensor Module |
GPIO0 |
GPIO17 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/34_tracking/
Step 3: Compile.
gcc tracking.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define TrackSensorPin 0
#define LedPin 1
int main(void)
pinMode(TrackSensorPin, INPUT);
pinMode(LedPin, OUTPUT);
if(digitalRead(TrackSensorPin) == LOW){
printf("White line is detected\n");
digitalWrite(LedPin, LOW); //led on
delay(100);
digitalWrite(LedPin, HIGH); //led off
else{
printf("...Black line is detected\n");
delay(100);
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 34_tracking.py
import RPi.GPIO as GPIO
TrackPin = 11
LedPin = 12
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(LedPin, GPIO.OUT) # Set LedPin's mode is output
GPIO.setup(TrackPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.output(LedPin, GPIO.HIGH) # Set LedPin high(+3.3V) to off led
def loop():
if GPIO.input(TrackPin) == GPIO.LOW:
print ('White line is detected')
time.sleep(0.5)
GPIO.output(LedPin, GPIO.LOW) # led on
print ('...Black line is detected')
time.sleep(0.5)
GPIO.output(LedPin, GPIO.HIGH) # led off
def destroy():
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
When the tracking sensor encounters black lines, a string “Black Line is detected” will be printed on the screen.
