Lesson 24 Touch Switch¶
A touch sensor operate with the conductivity of human body. When you touch the metal on the base electrode of the transistor, the level of pin SIG will turn over.
1 * Raspberry Pi
1 * Breadboard
1 * Touch sensor module
1 * Dual-Color LED module
2 * 3-Pin anti-reverse cable
Experimental Principle
In this experiment, touch the base electrode of the transistor by fingers to make it conduct as human body itself is a kind of conductor and an antenna that can receive electromagnetic waves in the air. These electromagnetic wave signals collected from the human body are amplified by the transistor and processed by the comparator on the module to output steady signals. The schematic diagram:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
Touch Sensor Module |
GPIO0 |
GPIO17 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Raspberry Pi |
Dual-Color LED Module |
GPIO1 |
GPIO18 |
R |
GND |
GND |
GND |
GPIO2 |
GPIO27 |
G |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/24_touch_switch/
Step 3: Compile.
gcc touch_switch.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <wiringPi.h>
#include <stdio.h>
#define TouchPin 0
#define Gpin 2
#define Rpin 1
int tmp = 0;
void LED(int color)
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if (color == 0)
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
else if (color == 1)
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
else
printf("LED Error");
void Print(int x){
if (x != tmp){
if (x == 0)
printf("...ON\n");
if (x == 1)
printf("OFF..\n");
tmp = x;
int main(void)
pinMode(TouchPin, INPUT);
LED(digitalRead(TouchPin));
Print(digitalRead(TouchPin));
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 24_touch_switch.py
import RPi.GPIO as GPIO
TouchPin = 11
Gpin = 13
Rpin = 12
tmp = 0
def setup():
GPIO.setmode(GPIO.BOARD) # Numbers GPIOs by physical location
GPIO.setup(Gpin, GPIO.OUT) # Set Green Led Pin mode to output
GPIO.setup(Rpin, GPIO.OUT) # Set Red Led Pin mode to output
GPIO.setup(TouchPin, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Set BtnPin's mode is input, and pull up to high level(3.3V)
def Led(x):
if x == 0:
GPIO.output(Rpin, 1)
GPIO.output(Gpin, 0)
if x == 1:
GPIO.output(Rpin, 0)
GPIO.output(Gpin, 1)
def Print(x):
global tmp
if x != tmp:
if x == 0:
print (' **********')
print (' * ON *')
if x == 1:
print (' * OFF *')
tmp = x
def loop():
Led(GPIO.input(TouchPin))
Print(GPIO.input(TouchPin))
def destroy():
GPIO.output(Gpin, GPIO.HIGH) # Green led off
GPIO.output(Rpin, GPIO.HIGH) # Red led off
GPIO.cleanup() # Release resource
setup()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Now, touch the metal disk, you can see the LED change its colors and “ON” and “OFF” printed on the screen.
