Lesson 22 Gas Sensor¶
Gas Sensor MQ-2 is a sensor for flammable gas and smoke by detecting the concentration of combustible gas in the air. They are used in gas detecting equipment for smoke and flammable gasses in household, industry or automobile.
1 * Raspberry Pi
1 * Breadboard
1 * Active Buzzer module
1 * PCF8591
1 * Gas sensor module
1 * 3-Pin anti-reverse cable
1 * 4-Pin anti-reverse cable
Several Jumper wires
Experimental Principle
MQ-2 gas sensor is a kind of surface ion type and N-type semiconductors, which uses tin oxide semiconductor gas sensitive material. When ambient temperature is in 200 ~ 300℃, tin oxide will adsorb oxygen in the air and form oxygen anion adsorption to decrease electron density in semiconductor so as to increase its resistance. When in contact with the smoke, if grain boundary barrier is modulated by the smoke and changed, it could cause surface conductivity change. So you can gain the information of the smoke existence, The higher the smoke concentration is, the more conductive the material becomes, thus the lower the output resistance is.
In this experiment, if harmful gases reach a certain concentration, the buzzer will beep to warn.
The schematic diagram of the module is as shown below:
Experimental Procedures
Step 1: Build the circuit.
Raspberry Pi |
GPIO Extension Board |
PCF8591 Module |
SDA |
SDA1 |
SDA |
SCL |
SCL1 |
SCL |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
Gas Sensor Module |
PCF8591 Module |
DO |
GPIO17 |
AO |
AIN0 |
VCC |
3V3 |
GND |
GND |
GND |
Raspberry Pi |
Active Buzzer Module |
GPIO1 |
GPIO18 |
SIG |
3.3V |
3V3 |
VCC |
GND |
GND |
GND |
For C Users:
Step 2: Change directory.
cd /home/pi/SunFounder_SensorKit_for_RPi2/C/22_gas_sensor/
Step 3: Compile.
gcc gas_sensor.c -lwiringPi
If it does not work after running, or there is an error prompt wiringPi.h: No such file or directory, please refer to WiringPi to install it.
Step 4: Run.
#include <stdio.h>
#include <wiringPi.h>
#include <pcf8591.h>
#include <math.h>
#define PCF 120
#define DOpin 0
#define Buzz 1
void Print(int x)
switch(x)
case 1:
printf("\n*********\n" );
printf( "* Saft~ *\n" );
printf( "*********\n\n");
break;
case 0:
printf("\n***************\n" );
printf( "* Danger Gas! *\n" );
printf( "***************\n\n");
break;
default:
printf("\n**********************\n" );
printf( "* Print value error. *\n" );
printf( "**********************\n\n");
break;
int main()
int analogVal;
int tmp, status, count;
if(wiringPiSetup() == -1){
// Setup pcf8591 on base pin 120, and address 0x48
pcf8591Setup(PCF, 0x48);
pinMode (DOpin, INPUT);
pinMode (Buzz, OUTPUT);
digitalWrite(Buzz, HIGH);
status = 0;
count = 0;
while(1) // loop forever
analogVal = analogRead(PCF + 0);
printf("%d\n", analogVal);
tmp = digitalRead(DOpin);
if (tmp != status)
Print(tmp);
status = tmp;
if (status == 0)
count ++;
if (count % 2 == 0)
{digitalWrite(Buzz, HIGH);}
else
{digitalWrite(Buzz, LOW);}
else
count = 0;
delay (200);
For Python Users:
cd /home/pi/SunFounder_SensorKit_for_RPi2/Python/
Step 3: Run.
sudo python3 22_gas_sensor.py
import PCF8591 as ADC
import RPi.GPIO as GPIO
import math
DO = 17
Buzz = 18
GPIO.setmode(GPIO.BCM)
def setup():
ADC.setup(0x48)
GPIO.setup (DO, GPIO.IN)
GPIO.setup (Buzz, GPIO.OUT)
GPIO.output (Buzz, 1)
def Print(x):
if x == 1:
print ('')
print (' *********')
print (' * Safe~ *')
print ('')
if x == 0:
print ('')
print (' ***************')
print (' * Danger Gas! *')
print ('')
def loop():
status = 1
count = 0
print (ADC.read(0))
tmp = GPIO.input(DO)
if tmp != status:
Print(tmp)
status = tmp
if status == 0:
count += 1
if count % 2 == 0:
GPIO.output(Buzz, 1)
GPIO.output(Buzz, 0)
count = 0
time.sleep(0.2)
def destroy():
GPIO.cleanup()
if __name__ == '__main__':
setup()
loop()
destroy()
Place a lighter close to the MQ-2 gas sensor, and press the switch to release gasses. A value between 0 and 255 will be displayed on the screen. If harmful gases reach a certain concentration, the buzzer will beep, and “Danger Gas!” will be printed on the screen.
You can also turn the shaft of the potentiometer on the module to raise or reduce the concentration threshold.
The MQ-2 gas sensor needs to be heated up for a while. Wait until the value printed on screen stays steady and the sensor gets warm, which means it can work normally and sensitively at that time.
It is normal that the gas sensor generates heat. Actually, the higher the temperature is, the sensor is more sensitive.
