SunFounder raphael-kit
latest
  • Introduction
  • Components List and Introduction
  • Preparation
  • GPIO Extension Board
  • Download the Code
  • Play with C
  • Play with Python
  • Play with Processing
  • Play with Nodejs
    • What is Nodejs?
    • Install or update nodejs and npm
    • Check the pigpio
    • Output
    • Input
    • Extension
  • Play with Scratch
  • Appendix
  • FAQ
  • Thank You
  • Docs »
  • Play with Nodejs
  • Edit on GitHub
Play with Nodejs¶
  • What is Nodejs?
  • Check the pigpio
  • Output
    • 1.1 Displays
      • 1.1.1 Blinking LED
      • 1.1.2 RGB LED
      • 1.1.3 LED Bar Graph
      • 1.1.4 7-segment Display
      • 1.1.5 4-Digit 7-Segment Display
      • 1.1.6 LED Dot Matrix Module
      • 1.1.7 I2C LCD1602
    • 1.2 Sound
      • 1.2.1 Active Buzzer
    • 1.3 Drivers
      • 1.3.1 Motor
      • 1.3.2 Servo
      • 1.3.3 Relay
  • Input
    • 2.1 Controllers
      • 2.1.1 Button
      • 2.1.2 Micro Switch
      • 2.1.3 Touch Switch Module
      • 2.1.4 Slide Switch
      • 2.1.5 Tilt Switch
      • 2.1.6 Rotary Encoder Module
      • 2.1.7 Potentionmeter
      • 2.1.8 Keypad
      • 2.1.9 Joystick
    • 2.2 Sensors
      • 2.2.1 Photoresistor
      • 2.2.2 Thermistor
      • 2.2.3 DHT-11
      • 2.2.4 Reed Switch Module
      • 2.2.5 IR Obstacle Avoidance Sensor
      • 2.2.6 Speed Sensor Module
      • 2.2.7 PIR
      • 2.2.8 Ultrasonic Sensor Module
      • 2.2.9 MPU6050 Module
  • Extension
    • 3.1.1 Photograph Module
Next Previous
© Copyright 2021, SunFounder Revision a5008f4c.
Built with Sphinx using a theme provided by Read the Docs.
Read the Docs v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
Free document hosting provided by Read the Docs.
