2.1.9 Joystick
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use ADC0834 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node joystick.js
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
const ADC0834 = require('./adc0834.js').ADC0834;
const adc = new ADC0834(17, 18, 22);
const btn = new Gpio(25, {
mode: Gpio.INPUT,
pullUpDown: Gpio.PUD_UP,
setInterval(async() => {
x_val = await adc.read(0);
y_val = await adc.read(1);
btn_val = btn.digitalRead();
console.log(`x = ${x_val}, y = ${y_val}, btn = ${btn_val}\n`);
}, 100);
Code Explanation
We import an ADC0834 constructor to use the adc0834 module.
}, 100);
When reading the values of multiple channels of ADC0834 at the same time, asynchronous programming is required. We build a promise function here, And use the await instruction of async function to elegantly write this complex asynchronous task.
Phenomenon Picture
