2.2.3 DHT-11
The digital temperature and humidity sensor DHT11 is a composite sensor that contains a calibrated digital signal output of temperature and humidity. The technology of a dedicated digital modules collection and the technology of the temperature and humidity sensing are applied to ensure that the product has high reliability and excellent stability.
The sensors include a wet element resistive sensor and a NTC temperature sensor and they are connected to a high performance 8-bit microcontroller.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/nodejs/
Step 3: Install dependencies.
sudo npm install node-dht-sensor
Step 4: Run the code.
sudo node dht11.js
After the code runs, the program will print the temperature and humidity detected by DHT11 on the computer screen.
var sensor = require("node-dht-sensor");
setInterval(function(){
sensor.read(11, 17, function(err, temperature, humidity) {
if (!err) {
console.log(`temp: ${temperature}\`C, humidity: ${humidity}%`);
},1000);
Code Explanation
Import the module node-dht-sensor module, which provides functions for us to read the value of DHT-11.
For more details, please refer to: https://www.npmjs.com/package/node-dht-sensor
sensor.read(11, 17, function(err, temperature, humidity){...})
The node-dht-sensor module provides the read() function for us to read the measured temperature and humidity,
where 11 means DHT-11, 17 means and its connected to GPIO17.
if (!err) {
When there is no error in the reading, the temperature and humidity values are printed on the terminal.
Phenomenon Picture
