2.2.6 Speed Sensor Module
In this project, we will learn the use of the speed sensor module. A Speed sensor module is a type of tachometer that is used to measure the speed of a rotating object like a motor.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node speed_sensor_module.js
After the code runs, the green LED will light up. If you place an obstacle in the gap of the speed sensor module, the “light blocked” will be printed on the screen and the red LED will be lit. Remove the obstacle and the green LED will light up again.
const Rpin = new Gpio(22, { mode: Gpio.OUTPUT });
const Gpin = new Gpio(27, { mode: Gpio.OUTPUT });
const speedPin = new Gpio(17, {
mode: Gpio.INPUT,
pullUpDown: Gpio.PUD_DOWN,
edge: Gpio.EITHER_EDGE
speedPin.on('interrupt', (level) => {
if (level) {
console.log("Light was blocked");
Rpin.digitalWrite(level);
Gpin.digitalWrite(!level);
process.on('SIGINT', function () {
Rpin.digitalWrite(0);
Gpin.digitalWrite(0);
process.exit();
Code Explanation
The code of this example is almost the same as 2.1.5 Tilt Switch, so no need to repeat it.
