1.1.1 Blinking LED
In this project, we will learn how to make a blinking LED by programming. Through your settings, your LED can produce a series of interesting phenomena. Now, go for it.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
In this experiment, connect a 220Ω resistor to the anode (the long pin of the LED), then the resistor to 3.3 V, and connect the cathode (the short pin) of the LED to GPIO17 of Raspberry Pi. Therefore, to turn on an LED, we need to make GPIO17 low (0V) level. We can get this phenomenon by programming.
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/nodejs/
Change directory to the path of the code in this experiment via cd.
Step 3: Run the code
sudo node blink.js
Here sudo - superuser do, and python means to run the file by Python.
After the code runs, you will see the LED flashing.
Step 4: If you want to edit the code file blink.js,
press Ctrl + C to stop running the code. Then type the following
command to open blink.js:
nano blink.js
nano is a text editor tool. The command is used to open the code file blink.js by this tool.
Press Ctrl+X to exit. If you have modified the code, there will be a
prompt asking whether to save the changes or not. Type in Y (save)
or N (don’t save).
Then press Enter to exit. Type in nano blink.js again to
see the effect after the change.
The following is the program code:
const led = new Gpio(17,{mode: Gpio.OUTPUT});
var led_state = 0;
function blink_led(){
led.digitalWrite(led_state);
led_state = !led_state;
setInterval(blink_led,300);
Alternatively, write the code as a more js-specific arrow function:
var led_state = 0;
setInterval(() => {
}, 300);
Code Explanation
Import the Gpio constructor in the pigpio package in this way,
and then define a constant Gpio to represent this constructor.
With a variety of constructor, we can use js to control electronic devices.
pigpio can be used to implement fast GPIO, PWM, servo control, state change notification and interrupt handling.
The new keyword is used to construct instantiated objects of the class.
Connect the LED to the GPIO17 of the T-shaped expansion board,
set the LedPin mode to output and assign it to the constant led,
that is, construct a GPIO17 object led, and its mode is the output mode.
There are two ways to number the IO pins on the Raspberry Pi: BOARD number and BCM number. In our project, we use the BCM number. You need to set each channel used as input or output.
The setInterval() method can call functions or compute expressions with a specified period (in milliseconds).
Here we change the operating state of the LED with a period of 300ms.
The gpio.digitalWrite(level) method sets the gpio level to 1 or 0.
var led_state = 0;
setInterval(() => {
}, 300);
Rewrite the code as an arrow function to make the code shorter.
Phenomenon Picture
