1.3.3 Relay
In this project, we will learn to use a relay. It is one of the commonly used components in automatic control system. When the voltage, current, temperature, pressure, etc., reaches, exceeds or is lower than the predetermined value, the relay will connect or interrupt the circuit, to control and protect the equipment.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node relay.js
While the code is running, the LED lights up. In addition, you can hear a ticktock caused by breaking normally close contact and closing normally open contact.
const relay = new Gpio(17,{mode: Gpio.OUTPUT});
setInterval(() => {
relay.digitalWrite(!relay.digitalRead());
}, 500);
process.on('SIGINT',function(){
relay.digitalWrite(0);
process.exit();
Code Explanation
Import the pigpio module and instantiate an object relay of Gpio to control the IO port Gpio17, and set it to output mode.
setInterval(() => {
}, 500);
The relay is opened and closed continuously, and the LEDs will also be on and off continuously at intervals of 500ms.
process.exit();
When ctrl+c is caught, the relay is opened.
Phenomenon Picture
