2.2.2 Thermistor
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/list_2.2.2_thermistor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Thermistor
ADC0834
Schematic Diagram
../_images/image323.png ../_images/image324.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image202.png
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node thermistor.js
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
const ADC0834 = require('./adc0834.js').ADC0834;
exports.ADC0834 = ADC0834;
const adc = new ADC0834(17, 18, 27);
setInterval(() => {
  adc.read(0).then((value) => {
    var Vr = 5 * value / 255;
    var Rt = 10000 * Vr / (5 - Vr);
    var temp = 1 / ((Math.log(Rt/10000) / 3950)+(1 / (273.15 + 25)));
    var cel = (temp - 273.15).toFixed(2);
    var Fah = (cel * 1.8 + 32).toFixed(2);
    console.log(`Celsius: ${cel} C  Fahrenheit: ${Fah} F\n`);
  }, (error)=>{
    console.log("Error: " + error);
}, 1000);
Code Explanation
setInterval(() => {
  }, (error)=>{
}, 1000);
We can read the value of the thermistor through the statement adc.read(0).then((value) => {...})
These operations convert the thermistor value to a Celsius temperature value.
These two lines of code are used to calculate the voltage distribution from the read values, resulting in Rt (resistance of the thermistor).
This code refers to substituting Rt into the formula TK=1/(ln(RT/RN)/B+1/TN) to get the temperature in Kelvin.
This paragraph is to convert the Kelvin temperature to Celsius with two decimal places.
This paragraph converts Celsius to Fahrenheit with two decimal places.
Print Celsius, Fahrenheit and their units on the terminal.
Phenomenon Picture
../_images/image203.jpeg
