1.1.6 LED Dot Matrix Module
In this project, you will learn about LED Matrix Module. LED Matrix Module uses the MAX7219 driver to drive the 8 x 8 LED Matrix.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
wiringPi |
BCM |
SPIMOSI |
Pin 19 |
12 |
MOSI |
SPICE0 |
pin 24 |
10 |
CE0 |
SPISCLK |
Pin 23 |
14 |
SCLK |
Experimental Procedures
Step 1: Build the circuit.
Turn on the SPI before starting the experiment, refer to SPI Configuration for details.
cd ~/raphael-kit/nodejs/
Step 3: Install dependencies.
sudo npm install spi-device
Step 4: Run the code.
sudo node max7219_led_matrix.js
After running the code, the LED Dot Matrix displays from 0 to 9 and A to Z in sequence.
const spi = require('spi-device');
class MAX7219_LED_MATRIX {
constructor(bus, device) {
this.bus = bus;
this.device = device;
delay(ms) {
return new Promise((resolve, reject) => {setTimeout(resolve, ms)});
async write(addr, data) {
return new Promise((resolve, reject)=>{
const max7219 = spi.open(this.bus, this.device, (err)=>{
if (err) reject(err);
const message = [{
sendBuffer: Buffer.from([addr, data]),
receiveBuffer: Buffer.alloc(2),
byteLength: 2,
speedHz: 20000
max7219.transfer(message, (err, message)=>{
else resolve();
async init() {
await this.write(0x09, 0x00);
await this.write(0x0a, 0x03);
await this.write(0x0b, 0x07);
await this.write(0x0c, 0x01);
await this.write(0x0f, 0x00);
const DISP=[
[0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C],//0
[0x08,0x18,0x28,0x08,0x08,0x08,0x08,0x08],//1
[0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E],//2
[0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0],//3
[0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8],//4
[0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0],//5
[0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0],//6
[0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8],//7
[0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E],//8
[0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E],//9
[0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22],//A
[0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0],//B
[0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0],//C
[0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0],//D
[0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C],//E
[0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40],//F
[0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C],//G
[0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44],//H
[0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C],//I
[0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30],//J
[0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24],//K
[0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C],//L
[0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81],//M
[0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0],//N
[0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C],//O
[0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20],//P
[0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D],//Q
[0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21],//R
[0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C],//S
[0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8],//T
[0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C],//U
[0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18],//V
[0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0],//W
[0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41],//X
[0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8],//Y
[0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F],//Z
lm = new MAX7219_LED_MATRIX(0, 0);
async function main(){
lm.init();
for(let j=0;j<36;j++){
for(let i=1;i<9;i++){
lm.write(i, DISP[j][i-1]);
await lm.delay(1000);
main();
Code Explanation
Import the modules needed for spi communication.
When you have multiple devices that need spi communication, just connect the cs pins to different pins.
this.bus = bus;
delay(ms) {
const message = [{
byteLength: 2,
speedHz: 20000
else resolve();
Implement a MAX7219_LED_MATRIX class, and the write() function encapsulated in it can light up the matrix.
The async keyword is used to modify the function and is usually matched with the await keyword. The statement modified by the await keyword needs to wait for the previous code to finish running before executing, achieving the effect of synchronous blocking.
Instantiate an object lm of the MAX7219_LED_MATRIX class, so that we can call the encapsulated write() function inside.
for(let i=0;i<8;i++){
lm.write(i, DISP[j][i]);
The write(row,date) function allows you to display specified characters on the LED dot matrix,
The first parameter selects the row of the LED Matrix (8 rows in total),
The second parameter enters an 8-bit binary number to control the 8 LEDs of the row (0 means off, 1 means on).
The variable j is used to select the glyph, which is DISP[] . There are a total of 35 glyphs, 0~9 and A~Z.
For example, when j=1, the LED Maxtrix should display the image 1 .
The variable i is used to write the 8 data in the DISP[] glyph into the LED Matrix in turn. After the loop is completed, an 8x8 graphic can be generated.
For example, when j=1, i=1, the data of DISP[1][1] will be written here, that is, 0x18,
This will cause the second row of the LED Maxtrix to display the image 00011000.
