SunFounder Ulimate Raphael Kit for Raspberry Pi
latest
  • About Video Course
  • Components List and Introduction
  • Install and Setup Raspberry Pi OS
  • GPIO Extension Board
  • Download the Code
  • Play with Python
  • Play with C
  • Play with Processing
  • Play with Nodejs
    • What is Nodejs?
    • Install or update nodejs and npm
    • Check the pigpio
    • Output
    • Input
      • 2.1 Controllers
        • 2.1.1 Button
        • 2.1.2 Micro Switch
        • 2.1.3 Touch Switch Module
        • 2.1.4 Slide Switch
        • 2.1.5 Tilt Switch
        • 2.1.6 Rotary Encoder Module
        • 2.1.7 Potentionmeter
        • 2.1.8 Keypad
        • 2.1.9 Joystick
      • 2.2 Sensors
        • 2.2.1 Photoresistor
        • 2.2.2 Thermistor
        • 2.2.3 DHT-11
        • 2.2.4 Reed Switch Module
        • 2.2.5 IR Obstacle Avoidance Sensor
        • 2.2.6 Speed Sensor Module
        • 2.2.7 PIR
        • 2.2.8 Ultrasonic Sensor Module
        • 2.2.9 MPU6050 Module
    • Extension
  • Play with Scratch
  • Appendix
  • Thank You
  • Docs »
  • Play with Nodejs »
  • Input
  • Edit on GitHub
Input¶
2.1 Controllers¶
  • 2.1.1 Button
  • 2.1.5 Tilt Switch
  • 2.1.8 Keypad
  • 2.1.9 Joystick
2.2 Sensors¶
  • 2.2.2 Thermistor
  • 2.2.3 DHT-11
  • 2.2.7 PIR
Next Previous
© Copyright 2022, SunFounder Revision e57974f8.
Built with Sphinx using a theme provided by Read the Docs.
Read the Docs v: latest
Versions
latest
Downloads
pdf
html
epub
On Read the Docs
Project Home
Builds
Free document hosting provided by Read the Docs.
