2.1.6 Rotary Encoder Module
In this project, you will learn about Rotary Encoder. A rotary encoder is an electronic switch with a set of regular pulses in strictly timing sequence. When used with IC, it can achieve increment, decrement, page turning and other operations such as mouse scrolling, menu selection, and so on.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
chematic Diagram
Experimental Procedures
Step 1: Build the circuit.
In this example, we can connect the Rotary Encoder pin directly to the Raspberry Pi using a breadboard and 40-pin Cable, connect the GND of the Rotary Encoder to GND, 「+」to 5V, SW to digital GPIO27, DT to digital GPIO18, and CLK to digital GPIO 17.
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node rotary_encoder_module.js
You will see the count on the shell. When you turn the rotary encoder clockwise, the count is increased; when turn it counterclockwise, the count is decreased. If you press the switch on the rotary encoder, the readings will return to zero.
const clkPin = new Gpio(17, {
mode: Gpio.INPUT,
pullUpDown: Gpio.PUD_DOWN,
edge: Gpio.RISING_EDGE
const dtPin = new Gpio(18, {
mode: Gpio.INPUT,
const swPin = new Gpio(27, {
mode: Gpio.INPUT,
pullUpDown: Gpio.PUD_UP,
edge: Gpio.FALLING_EDGE
var globalCounter = 0;
clkPin.on('interrupt',()=>{
if(dtPin.digitalRead()==1){
globalCounter--;
else{
globalCounter++;
console.log(`globalCounter = ${globalCounter}`);
swPin.on('interrupt', () => {
globalCounter = 0;
Code Explanation
globalCounter--;
else{
globalCounter++;
When dtPin goes from low to high, if clkPin is high, the count decreases, otherwise the count increases.
globalCounter = 0;
The swPin will output low when the shaft is pressed. Let the globalCounter go to zero at this point
