2.1.7 Potentionmeter
The ADC function can be used to convert analog signals to digital signals, and in this experiment, ADC0834 is used to get the function involving ADC. Here, we implement this process by using potentiometer. Potentiometer changes the physical quantity – voltage, which is converted by the ADC function.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
cd ~/raphael-kit/nodejs/
Step 3: Run the code.
sudo node potentionmeter.js
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
const ADC0834 = require('./adc0834.js').ADC0834;
const adc = new ADC0834(17, 18, 27);
const led = new Gpio(22, {mode: Gpio.OUTPUT});
setInterval(() => {
adc.read(0).then((value) => {
console.log(`Current analogVal: ${value}\n`);
led.pwmWrite(value);
}, (error)=>{
console.log("Error: " + error);
}, 100);
Code Explanation
Import the pigpio module.
We import an ADC0834 constructor to use the adc0834 module.
Instantiate an ADC0834 object, the three parameters are its three pins.
This is a promise object, you may need to understand the concept from the following link.
setInterval(() => {
}, (error)=>{
}, 100);
The value of ADC0834 channel 0 (channel 0 is connected to the potentiometer) is read every 100ms, and the value will be stored in value.
Print value and use it to control the brightness of the LED, now you can see that the brightness of the LED changes with the value of the potentiometer.
Phenomenon Picture
