1.1.3 LED Bar Graph
In this project, we sequentially illuminate the lights on the LED Bar Graph.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Pay attention to the direction when connecting. If you connect it backwards, it will not light up.
cd ~/raphael-kit/nodejs/
Step 3: Compile the code.
sudo node led_bar_graph.js
After the code runs, you will see the LEDs on the LED bar turn on and off regularly.
var pins = [17, 18, 27, 22, 23, 24, 25, 2, 3, 8];
var leds = [];
for (let i = 0; i < pins.length; i++) {
leds[i] = new Gpio(pins[i], { mode: Gpio.OUTPUT });
function oddLedBarGraph() {
for (let i = 0; i < leds.length; i++) {
if (i % 2 == 1) {
leds[i].digitalWrite(1);
} else {
leds[i].digitalWrite(0);
function evenLedBarGraph() {
if (i % 2 == 0) {
} else {
var odd_even = 0;
setInterval(() => {
odd_even = (odd_even + 1) % 2;
if (odd_even == 1) {
oddLedBarGraph();
} else {
evenLedBarGraph();
}, 500);
Code Explanation
var pins = [17,18,27,22,23,24,25,2,3,8];
Because the led bar graph will use multiple pins, we create a constant array pins to store them in batches.
var leds = [];
Instantiate these pins as leds objects with a for loop.
if (i % 2 == 1) {
} else {
Implement an oddLedBarGraph() function to make the LEDs on the
odd digits of the LED bar graph light up.
if (i % 2 == 0) {
} else {
Implement an evenLedBarGraph() function to make the LEDs on the
even digits of the LED bar graph light up.
var odd_even = 0;
setInterval(() => {
oddLedBarGraph();
} else {
evenLedBarGraph();
}, 500);
The working state of the LED is switched every 500ms.
Phenomenon Picture
