Water Pump
Overview
The water pump is also a motor, which converts the mechanical energy of the motor or other external energy through a special structure to transport the liquid.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
DC Water Pump
TA6586 - Motor Driver Chip
Power Supply Module
To protect the Power Supply Module’s Power Pack, please fully charge it before using it for the first time.
../_images/25-pump_bb.png
Schematic Diagram
../_images/25_pump_schematic.png
  • You can open the file 25-pump.ino under the path of elite-explorer-kit-main\basic_project\25-pump.
25-pump.ino
 1/*
 2  This code controls a water pump using a TA6586 chip with an Arduino Uno R4.
 3  It turns on the pump for 5 seconds and then turns it off.
 5  Board: Arduino Uno R4
 6  Component: Water pump and TA6586 chip
 7*/
 8
 9// Define the control pins for the TA6586 chip
10const int motorBI = 9;  // Backward Input pin
11const int motorFI = 10; // Forward Input pin
12
13void setup() {
14  // Configure the motor control pins as output
15  pinMode(motorBI, OUTPUT);
16  pinMode(motorFI, OUTPUT);
17
18  // Turn on the water pump by setting the control pins
19  digitalWrite(motorBI, HIGH);
20  digitalWrite(motorFI, LOW);
21
22  // Keep the pump on for 5 seconds
23  delay(5000);
24
25  // Turn off the water pump
26  digitalWrite(motorFI, LOW);
27  digitalWrite(motorBI, LOW);  // This line was missing in the original code to fully turn off the pump
28}
29
30void loop() {
31  // Empty loop, no operation is done here
32}
Attach the tubing to the pump and position it in the basin. Once the code is successfully uploaded, the water pump will turn on and remain active for five seconds. When conducting this experiment, please ensure that the circuit is kept away from water to prevent any potential short circuits.
Code Analysis
The motor can be driven by providing a voltage difference between the copper sheets at both sides of the motor.
