PIR Motion Sensor Module
Overview
In this lesson, you will learn about PIR motion sensor module. The Passive Infrared(PIR) Motion Sensor is a sensor that detects motion. It is commonly used in security systems and automatic lighting systems. The sensor has two slots that detect infrared radiation. When an object, such as a person, passes in front of the sensor, it detects a change in the amount of infrared radiation and triggers an output signal.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
../_images/05-pir_bb.png
Schematic Diagram
../_images/05-pir_schematic.png
  • You can open the file 05-pir_motion_sensor.ino under the path of elite-explorer-kit-main\basic_project\05-pir_motion_sensor directly.
 1/*
 2  This code reads the digital input from a PIR (passive infrared) motion sensor connected to pin 2.
 3  If the digital input is HIGH, it prints the message "Somebody here!" to the serial monitor.
 5  Board: Arduino Uno R4
 6  Component: PIR (passive infrared) motion sensor
 7*/
 8
 9// Define the pin number for the PIR sensor
10const int pirPin = 2;
11// Declare and initialize the state variable
12int state = 0;
13
14void setup() {
15  pinMode(pirPin, INPUT);  // Set the PIR pin as an input
16  Serial.begin(9600);      // Start serial communication with a baud rate of 9600
17}
18
19void loop() {
20  state = digitalRead(pirPin);         // Read the state of the PIR sensor
21  if (state == HIGH) {                 // If the PIR sensor detects movement (state = HIGH)
22    Serial.println("Somebody here!");  // Print "Somebody here!" to the serial monitor
23  } else {
24    Serial.println("Monitoring...");
25    delay(100);
26  }
27}
After uploading the code to the Arduino Uno board, you can open the serial monitor to observe the sensor’s output. When the PIR (passive infrared) motion sensor detects movement, the serial monitor will display the message “Somebody here!” to indicate that motion has been detected. If no motion is detected, the message “Monitoring…” will be shown instead.
The PIR sensor outputs a digital HIGH or LOW signal, corresponding to detected or undetected motion, respectively. Unlike an analog sensor that provides a range of values, the digital output from this PIR sensor will either be HIGH (typically represented as ‘1’) or LOW (typically represented as ‘0’).
Note that the actual sensitivity and range of detection can vary based on the PIR sensor’s characteristics and the environmental conditions. Therefore, it is advisable to calibrate the sensor according to your specific needs.
