OLED
Overview
In this lesson, you will learn about OLED Displays using the SSD1306 driver. OLED (Organic Light-Emitting Diodes) displays are widely used in various electronic devices such as smartwatches, mobile phones, and even televisions. The SSD1306 is a single-chip CMOS OLED/PLED driver with controller for organic/polymer light emitting diode dot-matrix graphic display system. It offers a crisp and clear visual output through the means of organic material-based diodes that emit light when an electric current passes through them.
In the code provided, an OLED display is interfaced with an Arduino board via the I2C protocol. The code uses the Adafruit SSD1306 library to control the display. The program covers various functionalities such as:
Displaying text: “Hello world!” is printed on the screen.
Inverted text: The text “Hello world!” is displayed in an inverted color scheme.
Font Size: The text “Hello!” is displayed with an increased font size.
Numerical Display: The numbers 123456789 are displayed.
ASCII Characters: A set of ASCII characters are displayed.
Scrolling: Text is scrolled horizontally across the display.
Bitmap Display: A predefined bitmap image is displayed on the OLED screen.
This OLED display can be used in a multitude of applications including digital clocks, mini game consoles, information displays, and so on. It offers a great way to provide a user interface in compact and portable devices.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
You can open the file
15-oled.inounder the path ofelite-explorer-kit-main\basic_project\15-oleddirectly.Or copy this code into Arduino IDE.
To install the library, use the Arduino Library Manager and search for “Adafruit SSD1306” and “Adafruit GFX” and install it.
1/*
2 This code initializes an OLED display (SSD1306) using the Adafruit SSD1306 library,
3 and displays various text, numbers, and scroll animations on the screen.
5 Board: Arduino Uno R4 (or R3)
6 Component: OLED (SSD1306)
7 Library: https://github.com/adafruit/Adafruit_SSD1306 (Adafruit SSD1306 by Adafruit)
8 https://github.com/adafruit/Adafruit-GFX-Library (Adafruit GFX Library by Adafruit)
9*/
10
11#include <SPI.h>
12#include <Wire.h>
13#include <Adafruit_GFX.h>
14#include <Adafruit_SSD1306.h>
15
16#define SCREEN_WIDTH 128 // OLED display width, in pixels
17#define SCREEN_HEIGHT 64 // OLED display height, in pixels
18
19// Declaration for SSD1306 display connected using I2C
20#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
21#define SCREEN_ADDRESS 0x3C
22Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
23
24//Bitmap data
25static const unsigned char PROGMEM sunfounderIcon[] = {
26 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x7f, 0xff, 0xff, 0xff,
27 0xff, 0xff, 0xff, 0xf0, 0x1f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x0f, 0xff, 0xff, 0xff,
28 0xff, 0xff, 0xff, 0xc0, 0x07, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x03, 0xff, 0xff, 0xff,
29 0xff, 0xff, 0xff, 0x00, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x7f, 0xff, 0xff,
30 0xff, 0xff, 0xfc, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x1f, 0xff, 0xff,
31 0xff, 0xff, 0xf0, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xe0, 0x01, 0x00, 0x07, 0xff, 0xff,
32 0xff, 0xff, 0xc0, 0x07, 0xc0, 0x01, 0xff, 0xff, 0xff, 0xff, 0x80, 0x0f, 0xe0, 0x00, 0xff, 0xff,
33 0xff, 0xff, 0x00, 0x1f, 0xf0, 0x00, 0x7f, 0xff, 0xff, 0xfe, 0x00, 0x3f, 0xf8, 0x00, 0x3f, 0xff,
34 0xff, 0xfc, 0x00, 0x7f, 0xfe, 0x00, 0x0f, 0xff, 0xff, 0xfc, 0x00, 0xfe, 0xff, 0x00, 0x07, 0xff,
35 0xff, 0xf8, 0x01, 0xfc, 0x7f, 0x80, 0x03, 0xff, 0xff, 0xf0, 0x03, 0xf8, 0x3f, 0xc0, 0x01, 0xff,
36 0xff, 0xe0, 0x07, 0xf0, 0x0f, 0xe0, 0x00, 0xff, 0xff, 0xc0, 0x0f, 0xe0, 0x07, 0xf8, 0x00, 0x3f,
37 0xff, 0x80, 0x0f, 0xc0, 0x03, 0xfc, 0x00, 0x7f, 0xff, 0x00, 0x1f, 0xc0, 0x01, 0xfe, 0x00, 0xff,
38 0xff, 0x00, 0x0f, 0xe0, 0x00, 0x7f, 0x81, 0xff, 0xff, 0x00, 0x0f, 0xf0, 0x00, 0x3f, 0xc3, 0xff,
39 0xff, 0x80, 0x03, 0xfc, 0x00, 0x1f, 0xe7, 0xff, 0xff, 0xc0, 0x01, 0xfe, 0x00, 0x0f, 0xff, 0xff,
40 0xff, 0xe0, 0x00, 0xff, 0x00, 0x03, 0xff, 0xff, 0xff, 0xf0, 0x00, 0x7f, 0x80, 0x01, 0xff, 0xff,
41 0xff, 0xf8, 0x00, 0x1f, 0xe0, 0x00, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x0f, 0xf0, 0x00, 0x7f, 0xff,
42 0xff, 0xff, 0x00, 0x07, 0xf8, 0x00, 0x3f, 0xff, 0xff, 0xff, 0x80, 0x03, 0xfc, 0x00, 0x0f, 0xff,
43 0xff, 0xff, 0xc0, 0x00, 0xff, 0x00, 0x07, 0xff, 0xff, 0xff, 0xe0, 0x00, 0x7f, 0x80, 0x03, 0xff,
44 0xff, 0xff, 0xf8, 0x00, 0x3f, 0xc0, 0x01, 0xff, 0xff, 0xf3, 0xfc, 0x00, 0x1f, 0xe0, 0x00, 0xff,
45 0xff, 0xe1, 0xfe, 0x00, 0x07, 0xf8, 0x00, 0x7f, 0xff, 0xc0, 0x7f, 0x00, 0x03, 0xf8, 0x00, 0x7f,
46 0xff, 0x80, 0x3f, 0xc0, 0x01, 0xfc, 0x00, 0xff, 0xff, 0x00, 0x1f, 0xe0, 0x03, 0xf8, 0x00, 0xff,
47 0xfe, 0x00, 0x0f, 0xf0, 0x03, 0xf0, 0x01, 0xff, 0xff, 0x80, 0x07, 0xf8, 0x07, 0xe0, 0x03, 0xff,
48 0xff, 0xc0, 0x01, 0xfc, 0x0f, 0xc0, 0x07, 0xff, 0xff, 0xe0, 0x00, 0xff, 0x1f, 0xc0, 0x0f, 0xff,
49 0xff, 0xf0, 0x00, 0x7f, 0xbf, 0x00, 0x1f, 0xff, 0xff, 0xf8, 0x00, 0x3f, 0xff, 0x00, 0x3f, 0xff,
50 0xff, 0xfe, 0x00, 0x0f, 0xfe, 0x00, 0x7f, 0xff, 0xff, 0xff, 0x00, 0x07, 0xfc, 0x00, 0xff, 0xff,
51 0xff, 0xff, 0x80, 0x03, 0xf8, 0x01, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x01, 0xf0, 0x03, 0xff, 0xff,
52 0xff, 0xff, 0xf0, 0x00, 0x00, 0x07, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x00, 0x00, 0x0f, 0xff, 0xff,
53 0xff, 0xff, 0xfc, 0x00, 0x00, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xfe, 0x00, 0x00, 0x1f, 0xff, 0xff,
54 0xff, 0xff, 0xff, 0x00, 0x00, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x7f, 0xff, 0xff,
55 0xff, 0xff, 0xff, 0xe0, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xf0, 0x01, 0xff, 0xff, 0xff,
56 0xff, 0xff, 0xff, 0xf8, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfc, 0x07, 0xff, 0xff, 0xff,
57 0xff, 0xff, 0xff, 0xff, 0x0f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff
58};
59
60void setup() {
61 Serial.begin(9600);
62
63 // initialize the OLED object
64 if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
65 Serial.println(F("SSD1306 allocation failed"));
66 for (;;)
67 ;
68 }
69
70 // Clear the buffer.
71 display.clearDisplay();
72
73 // Display Text
74 display.setTextSize(1); // Set text size
75 display.setTextColor(WHITE); // Set text color
76 display.setCursor(0, 28); // Set cursor position
77 display.println("Hello world!");
78 display.display(); // Display the content on the screen
79 delay(2000);
80 display.clearDisplay(); // Clear the screen
81
82 // Display Inverted Text
83 display.setTextColor(BLACK, WHITE); // 'inverted' text
84 display.setCursor(0, 28);
85 display.println("Hello world!");
86 display.display();
87 delay(2000);
88 display.clearDisplay();
89
90 // Changing Font Size
91 display.setTextColor(WHITE);
92 display.setCursor(0, 24);
93 display.setTextSize(2);
94 display.println("Hello!");
95 display.display();
96 delay(2000);
97 display.clearDisplay();
98
99 // Display Numbers
100 display.setTextSize(1);
101 display.setCursor(0, 28);
102 display.println(123456789);
103 display.display();
104 delay(2000);
105 display.clearDisplay();
106
107 // Display ASCII Characters
108 display.setCursor(0, 24);
109 display.setTextSize(2);
110 for (int i = 1; i < 8; i++) {
111 display.write(i);
112 }
113 display.display();
114 delay(2000);
115 display.clearDisplay();
116
117 // Scroll full screen
118 display.setCursor(0, 0);
119 display.setTextSize(1);
120 display.println("Full");
121 display.println("screen");
122 display.println("scrolling!");
123 display.display();
124 display.startscrollright(0x00, 0x07); // Scroll the screen to the right
125 delay(5000);
126 display.stopscroll();
127 delay(1000);
128 display.startscrollleft(0x00, 0x07); // Scroll the screen to the left
129 delay(5000);
130 display.stopscroll();
131 delay(1000);
132 display.clearDisplay();
133
134 // Scroll part of the screen
135 display.setCursor(0, 0);
136 display.setTextSize(1);
137 display.println("Scroll");
138 display.println("some part");
139 display.println("of the screen.");
140 display.display();
141 display.startscrollright(0x00, 0x00); // Scroll the first column of the screen to the right
142 delay(4000);
143 display.stopscroll();
144 display.clearDisplay();
145
146 // Display bitmap
147 display.drawBitmap(32, 0, sunfounderIcon, 64, 64, WHITE);
148 display.display();
149}
150
151void loop() {
152}
Code Analysis
Library Inclusion and Initial Definitions: The necessary libraries for interfacing with the OLED are included. Following that, definitions regarding the OLED’s dimensions and I2C address are provided.
Adafruit SSD1306: This library is designed to help with the interfacing of the SSD1306 OLED display. It provides methods to initialize the display, control its settings, and display content.
Adafruit GFX Library: This is a core graphics library for displaying text, producing colors, drawing shapes, etc., on various screens including OLEDs.
#include <SPI.h> #include <Wire.h> #include <Adafruit_GFX.h> #include <Adafruit_SSD1306.h> #define SCREEN_WIDTH 128 // OLED display width, in pixels #define SCREEN_HEIGHT 64 // OLED display height, in pixels #define OLED_RESET -1 #define SCREEN_ADDRESS 0x3C
Bitmap Data: Bitmap data for displaying a custom icon on the OLED screen. This data represents an image in a format that the OLED can interpret.
You can use this online tool called image2cpp that can turn your image into an array.
The
PROGMEMkeyword denotes that the array is stored in the program memory of the Arduino microcontroller. Storing data in program memory(PROGMEM) instead of RAM can be helpful for large amounts of data, which would otherwise take up too much space in RAM.static const unsigned char PROGMEM sunfounderIcon[] = {...};
Setup Function (Initialization and Display): The
setup()function initializes the OLED and displays a series of patterns, texts, and animations.void setup() { ... // Serial initialization and OLED object initialization ... // Displaying various text, numbers, and animations }
