Thermistor
Overview
In this lesson, you will learn how to use thermistor. Thermistor can be used as electronic circuit components for temperature compensation of instrument circuits. In the current meter, flowmeter, gas analyzer, and other devices. It can also be used for overheating protection, contactless relay, constant temperature, automatic gain control, motor start, time delay, color TV automatic degaussing, fire alarm and temperature compensation.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
Thermistor
In this example, we use the analog pin A0 to get the value of Thermistor. One pin of thermistor is connected to 5V, and the other is wired up to A0. At the same time, a 10kΩ resistor is connected with the other pin before connecting to GND.
../_images/02-thermistor_bb.png
Schematic Diagram
../_images/02_thermistor_schematic.png
  • You can open the file 02-thermistor.ino under the path of elite-explorer-kit-main\basic_project\02-thermistor directly.
02-thermistor.ino
 1/*
 2  The code reads temperature data from a thermistor connected to analog pin A0 on an Arduino board.
 3  It calculates the temperature in both Celsius and Fahrenheit using the Steinhart-Hart equation and
 4  prints the results to the Serial Monitor. The code uses a pull-up resistor and the thermistor's
 5  beta value for the calculations.
 7  Board: Arduino Uno R4
 8  Component: Thermistor
 9*/
10
11const int analogPin = A0;   // Analog pin where the thermistor is connected
12const int beta = 3950;      // Beta value of the thermistor
13const int resistance = 10;  // Value of the pull-up resistor in kΩ
14
15void setup() {
16  Serial.begin(9600);  // Initialize Serial communication at 9600 baud rate
17}
18
19void loop() {
20  // Read the analog value from the thermistor
21  int analogValue = analogRead(analogPin);
22
23  // Calculate temperature in Celsius using the Steinhart-Hart equation
24  float tempC = beta / (log((1025.0 * resistance / analogValue - resistance) / resistance) + beta / 298.0) - 273.0;
25
26  // Convert the temperature to Fahrenheit
27  float tempF = 1.8 * tempC + 32.0;
28
29  // Print temperature in Celsius to the Serial Monitor
30  Serial.print("Temp: ");
31  Serial.print(tempC);
32  Serial.println(" degree Celsius");
33
34  // Print temperature in Fahrenheit to the Serial Monitor
35  Serial.print("Temp: ");
36  Serial.print(tempF);
37  Serial.println(" degree Fahrenheit");
38
39  delay(200);  // Pause for 200 milliseconds before the next reading
40}
After uploading the code to the uno r4 board, you can open the serial monitor to check the current temperature.
The Kelvin temperature is calculated using the formula TK=1/(ln(RT/RN)/B+1/TN). This equation is derived from the Steinhart-Hart equation and simplifies calculations. You can also find more information about this formula on the detailed introduction page of the Thermistor.
