Joystick Module
Overview
A joystick is an input device consisting of a stick that pivots on a base and reports its angle or direction to the device it is controlling. Joysticks are often used to control video games and robots. A Joystick PS2 is used here.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Joystick Module
../_images/20-joystick_bb.png
Schematic Diagram
This module has two analog outputs (corresponding to X,Y biaxial offsets).
In this experiment, we use the Uno board to detect the moving direction of the Joystick knob.
../_images/20_joystick_schematic.png
  • You can open the file 20-joystick.ino under the path of elite-explorer-kit-main\basic_project\20-joystick directly.
20-joystick.ino
 1/*
 2  The code reads values from a joystick module and prints them on the serial monitor.
 3  The joystick module has two analog axes (X and Y), which are connected to Arduino
 4  pins A0 and A1. The decimal form of the X and Y axis values is read and displayed
 5  on the serial monitor.
 7  Board: Arduino Uno R4
 8  Component: Joystick Module
 9*/
10
11const int xPin = A0;  //the VRX attach to
12const int yPin = A1;  //the VRY attach to
13const int swPin = 8;  //the SW attach to
14
15void setup() {
16  pinMode(swPin, INPUT_PULLUP);
17  Serial.begin(9600);
18}
19
20void loop() {
21  Serial.print("X: ");
22  Serial.print(analogRead(xPin), DEC);  // print the value of VRX in DEC
23  Serial.print("|Y: ");
24  Serial.print(analogRead(yPin), DEC);  // print the value of VRX in DEC
25  Serial.print("|Z: ");
26  Serial.println(digitalRead(swPin));  // print the value of SW
27  delay(50);
28}
Now, when you push the rocker, the coordinates of the X and Y axes displayed on the Serial Monitor will change accordingly. Pressing the button will also display the coordinate Z=0.
Code Analysis
The code is use the serial monitor to print the value of the VRX and VRY pins of the joystick ps2.
void loop()
    delay(50);
