7-segment Display
Overview
A 7-segment display is a device that can display numerals and letters. It’s made up of seven LEDs connected in parallel. Different letters/numbers can be shown by connecting pins on the display to the power source and enabling the related pins, thus turning on the corresponding LED segments. In this lesson let’s learn how to display specific characters on it.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
In this experiment, connect each of pin a-g of the 7-Segment Display to one 1000 ohm current limiting resistor respectively and then to pin 4-11. GND connects to GND. By programming, we can set one or several of pin4-11 as High level to light up the corresponding LED(s).
You can open the file
13-7_segment.inounder the path ofelite-explorer-kit-main\basic_project\13-7_segmentdirectly.Or copy this code into Arduino IDE.
1/*
2 The code is designed to control a 7-segment display using an Arduino.
3 It sequentially displays numbers 1-9 and letters A-F on the 7-segment
4 display, with each symbol displayed for one second.
6 Board: Arduino Uno R4
7 Component: 7-segment Display
8*/
9
10// Define pins for each segment of the 7-segment display
11const int a = 7;
12const int b = 6;
13const int c = 5;
14const int d = 11;
15const int e = 10;
16const int f = 8;
17const int g = 9;
18const int dp = 4; // Decimal point
19
20void setup() {
21 // Set pins 4 to 11 as output
22 for (int thisPin = 4; thisPin <= 11; thisPin++) {
23 pinMode(thisPin, OUTPUT);
24 }
25 // Initialize display by turning off all segments
26 turnOffAllSegments();
27}
28
29void loop() {
30 // Display numbers 1 to 9 and letters A to F sequentially
31 digital_1(); delay(1000);
32 digital_2(); delay(1000);
33 digital_3(); delay(1000);
34 digital_4(); delay(1000);
35 digital_5(); delay(1000);
36 digital_6(); delay(1000);
37 digital_7(); delay(1000);
38 digital_8(); delay(1000);
39 digital_9(); delay(1000);
40 digital_A(); delay(1000);
41 digital_b(); delay(1000);
42 digital_C(); delay(1000);
43 digital_d(); delay(1000);
44 digital_E(); delay(1000);
45 digital_F(); delay(1000);
46}
47
48void digital_1() //display 1 to the 7-segment
49{
50 turnOffAllSegments();
51 digitalWrite(b, HIGH);
52 digitalWrite(c, HIGH);
53}
54
55void digital_2() //display 2 to the 7-segment
56{
57 turnOffAllSegments();
58 digitalWrite(a, HIGH);
59 digitalWrite(b, HIGH);
60 digitalWrite(g, HIGH);
61 digitalWrite(e, HIGH);
62 digitalWrite(d, HIGH);
63}
64
65void digital_3() //display 3 to the 7-segment
66{
67 turnOffAllSegments();
68 digitalWrite(a, HIGH);
69 digitalWrite(b, HIGH);
70 digitalWrite(c, HIGH);
71 digitalWrite(d, HIGH);
72 digitalWrite(g, HIGH);
73}
74void digital_4() //display 4 to the 7-segment
75{
76 turnOffAllSegments();
77 digitalWrite(b, HIGH);
78 digitalWrite(c, HIGH);
79 digitalWrite(f, HIGH);
80 digitalWrite(g, HIGH);
81}
82
83void digital_5() //display 5 to the 7-segment
84{
85 turnOffAllSegments();
86 digitalWrite(a, HIGH);
87 digitalWrite(f, HIGH);
88 digitalWrite(g, HIGH);
89 digitalWrite(c, HIGH);
90 digitalWrite(d, HIGH);
91}
92
93void digital_6() //display 6 to the 7-segment
94{
95 turnOffAllSegments();
96 digitalWrite(a, HIGH);
97 digitalWrite(f, HIGH);
98 digitalWrite(e, HIGH);
99 digitalWrite(d, HIGH);
100 digitalWrite(c, HIGH);
101 digitalWrite(g, HIGH);
102}
103
104void digital_7() //display 7 to the 7-segment
105{
106 turnOffAllSegments();
107 digitalWrite(a, HIGH);
108 digitalWrite(b, HIGH);
109 digitalWrite(c, HIGH);
110}
111
112void digital_8() //display 8 to the 7-segment
113{
114 turnOffAllSegments();
115 digitalWrite(a, HIGH);
116 digitalWrite(b, HIGH);
117 digitalWrite(c, HIGH);
118 digitalWrite(d, HIGH);
119 digitalWrite(e, HIGH);
120 digitalWrite(f, HIGH);
121 digitalWrite(g, HIGH);
122}
123
124void digital_9() //display 9 to the 7-segment
125{
126 turnOffAllSegments();
127 digitalWrite(a, HIGH);
128 digitalWrite(b, HIGH);
129 digitalWrite(c, HIGH);
130 digitalWrite(d, HIGH);
131 digitalWrite(f, HIGH);
132 digitalWrite(g, HIGH);
133}
134
135void digital_A() //display A to the 7-segment
136{
137 turnOffAllSegments();
138 digitalWrite(a, HIGH);
139 digitalWrite(b, HIGH);
140 digitalWrite(c, HIGH);
141 digitalWrite(e, HIGH);
142 digitalWrite(f, HIGH);
143 digitalWrite(g, HIGH);
144}
145
146void digital_b() //display b to the 7-segment
147{
148 turnOffAllSegments();
149 digitalWrite(c, HIGH);
150 digitalWrite(d, HIGH);
151 digitalWrite(e, HIGH);
152 digitalWrite(f, HIGH);
153 digitalWrite(g, HIGH);
154}
155
156void digital_C() //display C to the 7-segment
157{
158 turnOffAllSegments();
159 digitalWrite(a, HIGH);
160 digitalWrite(f, HIGH);
161 digitalWrite(e, HIGH);
162 digitalWrite(d, HIGH);
163}
164
165void digital_d() //display d to the 7-segment
166{
167 turnOffAllSegments();
168 digitalWrite(b, HIGH);
169 digitalWrite(c, HIGH);
170 digitalWrite(d, HIGH);
171 digitalWrite(e, HIGH);
172 digitalWrite(g, HIGH);
173}
174
175void digital_E() //display E to the 7-segment
176{
177 turnOffAllSegments();
178 digitalWrite(a, HIGH);
179 digitalWrite(d, HIGH);
180 digitalWrite(e, HIGH);
181 digitalWrite(f, HIGH);
182 digitalWrite(g, HIGH);
183}
184
185void digital_F() //display F to the 7-segment
186{
187 turnOffAllSegments();
188 digitalWrite(a, HIGH);
189 digitalWrite(e, HIGH);
190 digitalWrite(f, HIGH);
191 digitalWrite(g, HIGH);
192}
193
194void turnOffAllSegments() {
195 // Turn off all segments of the 7-segment display
196 for (int thisPin = 4; thisPin <= 11; thisPin++) {
197 digitalWrite(thisPin, LOW);
198 }
199}
Code Analysis
The code may be a little long for this experiment. But the syntax is simple. Let’s take a look.
Call the function in loop()
digital_1(); //display 1 to the 7-segment
delay(1000); //wait for a second
digital_2(); //display 2 to the 7-segment
digital_3(); //display 3 to the 7-segment
digital_4(); //display 4 to the 7-segment
Calling these functions into the loop() is to let the 7-Segment display 0-F. The functions are shown below. Take digital_2() for example:
Detailed analysis of digital_2()
First, we need to understand how the numeral 2 appears on the 7-Segment display. It is achieved by powering on segments a, b, d, e, and g. In programming, pins connected to these segments are set to a High level while c and f are set to Low level. We start by using the function turnOffAllSegments() to turn off all segments and then light up the required ones.
After running this part, the 7-segment will display 2. Similarly, the display of other characters are the same. Since the letters b and d in upper case, namely B and D, would look the same with 8 and 0 on the display, they are displayed in lower case instead.
