RGB LED
Overview
In this lesson, we will use PWM to control an RGB LED to flash various kinds of color. When different PWM values are set to the R, G, and B pins of the LED, its brightness will be different. When the three different colors are mixed, we can see that the RGB LED flashes different colors.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
PWM
Pulse width modulation, or PWM, is a technique for getting analog results with digital means. Digital control is used to create a square wave, a signal switched between on and off. This on-off pattern can simulate voltages in between full on (5 Volts) and off (0 Volts) by changing the portion of the time the signal spends on versus the time that the signal spends off. The duration of “on time” is called pulse width. To get varying analog values, you change, or modulate, that width. If you repeat this on-off pattern fast enough with some device, an LED for example, it would be like this: the signal is a steady voltage between 0 and 5V controlling the brightness of the LED. (See the PWM description on the official website of Arduino).
In the graphic below, the green lines represent a regular time period. This duration or period is the inverse of the PWM frequency. In other words, with Arduino’s PWM frequency at about 500Hz, the green lines would measure 2 milliseconds each.
A call to analogWrite() is on a scale of 0 - 255, such that analogWrite(255) requests a 100% duty cycle (always on), and analogWrite(127) is a 50% duty cycle (on half the time) for example.
You will find that the smaller the PWM value is, the smaller the value will be after being converted into voltage. Then the LED becomes dimmer accordingly. Therefore, we can control the brightness of the LED by controlling the PWM value.
Schematic Diagram
You can open the file
11-rgb_led.inounder the path ofelite-explorer-kit-main\basic_project\11-rgb_leddirectly.Or copy this code into Arduino IDE.
1/*
2 The code controls an RGB LED connected to an Arduino. It cycles through
3 a sequence of colors by adjusting the intensity of the red, green, and blue
4 LEDs. The function color(int red, int green, int blue) is used to set the
5 color of the RGB LED.
7 Board: Arduino Uno R4
8 Component: RGB LED
9*/
10
11// Define pin numbers for the RGB LED
12const int redPin = 11; // Red pin connected to digital pin 11
13const int greenPin = 10; // Green pin connected to digital pin 10
14const int bluePin = 9; // Blue pin connected to digital pin 9
15
16// Initialization function
17void setup() {
18 // Set RGB LED pins as output
19 pinMode(redPin, OUTPUT);
20 pinMode(greenPin, OUTPUT);
21 pinMode(bluePin, OUTPUT);
22}
23
24// Main loop function
25void loop() {
26 // Cycle through basic colors
27 color(255, 0, 0); // Red
28 delay(1000); // Wait for 1 second
29 color(0, 255, 0); // Green
30 delay(1000); // Wait for 1 second
31 color(0, 0, 255); // Blue
32 delay(1000); // Wait for 1 second
33
34 // Cycle through blended colors
35 color(255, 0, 252); // Magenta
36 delay(1000); // Wait for 1 second
37 color(237, 109, 0); // Orange
38 delay(1000); // Wait for 1 second
39 color(255, 215, 0); // Yellow
40 delay(1000); // Wait for 1 second
41 color(34, 139, 34); // Forest Green
42 delay(1000); // Wait for 1 second
43 color(0, 112, 255); // Light Blue
44 delay(1000); // Wait for 1 second
45 color(0, 46, 90); // Indigo
46 delay(1000); // Wait for 1 second
47 color(128, 0, 128); // Purple
48 delay(1000); // Wait for 1 second
49}
50
51// Function to set the RGB LED color
52void color(int red, int green, int blue) {
53 // Write analog values to the RGB pins
54 analogWrite(redPin, red);
55 analogWrite(greenPin, green);
56 analogWrite(bluePin, blue);
57}
Once the code is successfully uploaded, you will observe the RGB LED flashing in a circular pattern of red, green, and blue initially. It will then proceed to flash in the sequence of red, orange, yellow, green, blue, indigo, and purple.
Code Analysis
Set the color
Here use the color() function to set the color of the RGB LED. In the
code, it is set to flash 7 different colors.
You can use the paint tool on your computer to get the RGB value.
Open the paint tool on your computer and click to Edit colors.
Select one color, then you can see the RGB value of this color. Fill them in the code.
Due to hardware and environmental factors, the colors displayed on computer screens and RGB LEDs may vary even when using the same RGB values.
void loop() // run over and over again { // Basic colors: color(255, 0, 0); // turn the RGB LED red delay(1000); // delay for 1 second color(0,255, 0); // turn the RGB LED green delay(1000); // delay for 1 second color(0, 0, 255); // turn the RGB LED blue delay(1000); // delay for 1 second // Example blended colors: color(255,0,252); // turn the RGB LED red delay(1000); // delay for 1 second color(237,109,0); // turn the RGB LED orange delay(1000); // delay for 1 second color(255,215,0); // turn the RGB LED yellow ......
color() function
void color (int red, int green, int blue)
// the color generating function
Define three unsigned char variables, red, green and blue. Write their values to redPin, greenPin and bluePin. For example, color(128,0,128) is to write 128 to redPin, 0 to greenPin and 128 to bluePin. Then the result is the LED flashing purple.
analogWrite(): Writes an analog value (PWM wave) to a pin. It has nothing to do with an analog pin, but is just for PWM pins. You do not need to call the pinMode() to set the pin as output before calling analogWrite().
