Active Buzzer
Overview
The active buzzer is a typical digital output device that is as easy to use as lighting up an LED!
Two types of buzzers are included in the kit. We need to use active buzzer. Turn them around, the sealed back (not the exposed PCB) is the one we want.
../_images/16_buzzer.png
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
Transistor
Buzzer
When connecting the buzzer, make sure to check its pins. The longer pin is the anode and the shorter one is the cathode. It’s important not to mix them up, as doing so will prevent the buzzer from producing any sound.
../_images/16-active_buzzer_bb.png
Schematic Diagram
../_images/16_active_buzzer_schematic.png
  • You can open the file 16-active_buzzer.ino under the path of elite-explorer-kit-main\basic_project\16-active_buzzer directly.
 1/*
 2  This code controls an active buzzer connected to pin 8 on an Arduino Uno R4.
 3  The buzzer will be turned on for 1 second and then turned off for 1 second, continuously.
 5  Board: Arduino Uno R4
 6  Component: Active Buzzer
 7*/
 8
 9// Declare the pin where the buzzer is connected
10const int buzzerPin = 8;
11
12// Initialize the pin as an output
13void setup() {
14  pinMode(buzzerPin, OUTPUT);
15}
16
17// Main loop
18void loop() {
19  digitalWrite(buzzerPin, HIGH);  // Turn the active buzzer on
20  delay(1000);                    // Wait for 1 second
21  digitalWrite(buzzerPin, LOW);   // Turn the active buzzer off
22  delay(1000);                    // Wait for 1 second
23}
After the code is uploaded successfully, you will hear a beep every second.
