MPR121
Overview
In this lesson, you will learn how to use MPR121. It’s a good option when you want to add a lot of touch switches to your project. The electrode of MPR121 can be extended with a conductor. If you connect a wire to a banana, you can turn the banana into a touch switch, thus realizing projects such as fruit piano.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
MPR121
In this example, we insert MPR121 into the breadboard. Get the GND of MPR121 connected to GND, 3.3V to 3V3, IRQ to the digital pin 2, SCL to the pin SCL(A5), and SDA to the pin SDA(A4). There are 12 electrodes for touch sensing.
MPR121 is powered by 3.3V, not 5V.
../_images/23-mpr121_bb.png
Schematic Diagram
../_images/23_mpr121_schematic.png
  • You can open the file 23-mpr121.ino under the path of elite-explorer-kit-main\basic_project\23-mpr121 directly.
  • The Adafruit MPR121 library is used here, you can install it from the Library Manager.
    ../_images/22_mpr121_lib.png
23-mpr121.ino
 1/*
 2  This Arduino code interfaces with the MPR121 Capacitive Touch Sensor
 3  using the Adafruit_MPR121 library. It initializes the sensor, reads
 4  the touch status of up to 12 pads, and prints messages to the Serial
 5  Monitor indicating when a pad is touched or released.
 7  Board: Arduino Uno R4
 8  Component: MPR121
 9  Library: https://github.com/adafruit/Adafruit_MPR121 (Adafruit_MPR121 by Adafruit)
10*/
11
12#include <Wire.h>
13#include "Adafruit_MPR121.h"
14
15#ifndef _BV
16#define _BV(bit) (1 << (bit))
17#endif
18
19// You can have up to 4 on one i2c bus but one is enough for testing!
20Adafruit_MPR121 cap = Adafruit_MPR121();
21
22// Keeps track of the last pins touched
23// so we know when buttons are 'released'
24uint16_t lasttouched = 0;
25uint16_t currtouched = 0;
26
27void setup() {
28  Serial.begin(9600);
29
30  while (!Serial) { // needed to keep leonardo/micro from starting too fast!
31    delay(10);
32  }
33
34  Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
35
36  // Default address is 0x5A, if tied to 3.3V its 0x5B
37  // If tied to SDA its 0x5C and if SCL then 0x5D
38  if (!cap.begin(0x5A)) {
39    Serial.println("MPR121 not found, check wiring?");
40    while (1);
41  }
42  Serial.println("MPR121 found!");
43  cap.setAutoconfig(true);
44}
45
46void loop() {
47  // Get the currently touched pads
48  currtouched = cap.touched();
49
50  for (uint8_t i=0; i<12; i++) {
51    // it if *is* touched and *wasn't* touched before, alert!
52    if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
53      Serial.print(i); Serial.println(" touched");
54    }
55    // if it *was* touched and now *isn't*, alert!
56    if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
57      Serial.print(i); Serial.println(" released");
58    }
59  }
60
61  // reset our state
62  lasttouched = currtouched;
63
64  // comment out this line for detailed data from the sensor!
65  return;
66
67  // debugging info, what
68  Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
69  Serial.print("Filt: ");
70  for (uint8_t i=0; i<12; i++) {
71    Serial.print(cap.filteredData(i)); Serial.print("\t");
72  }
73  Serial.println();
74  Serial.print("Base: ");
75  for (uint8_t i=0; i<12; i++) {
76    Serial.print(cap.baselineData(i)); Serial.print("\t");
77  }
78  Serial.println();
79
80  // put a delay so it isn't overwhelming
81  delay(100);
82}
After uploading the code to the UNO board, the touch state of pins MPR121 “1” and “0” will be recorded in a 12-bit boolean array. This array will then be printed on the serial monitor.
Code Analysis
This code facilitates communication and operation of the MPR121 touch sensor. It can detect the status of touch electrodes and print information about touched or released electrodes on the serial interface. If detailed sensor data is required, the relevant code can be uncommented.
Here’s an analysis of the code:
  1. Import Libraries:
    #include <Wire.h>
    • Wire.h: Used for I2C communication.
    • Adafruit_MPR121.h: Adafruit’s MPR121 library for operating the MPR121 touch sensor.
  2. Define the _BV Macro:
    #ifndef _BV
    #endif
    _BV(bit) defines a macro that converts a given bit into the corresponding binary value, similar to 1 << bit.
  3. Initialize Adafruit_MPR121 Class Instance:
    Create an instance of the Adafruit_MPR121 class named cap. The cap object will be used to communicate with and operate the MPR121 touch sensor.
  4. setup() Function:
    Initialize serial communication at a baud rate of 9600. then initialize the MPR121 touch sensor with the default I2C address of 0x5A. If initialization fails, print an error message and enter an infinite loop.
        Serial.begin(9600);
            delay(10);
            while (1);
  5. loop() Function:
    • Obtain the current touch status, returned as a 16-bit integer.
    • Iterate through the status of 12 electrodes (numbered from 0 to 11).
          // it if *is* touched and *wasnt* touched before, alert!
          // if it *was* touched and now *isnt*, alert!
      • If an electrode is touched and wasn’t touched before, print “x touched,” where x is the electrode number.
      • If an electrode was touched before but is not touched now, print “x released.”
    • Update lasttouched to store the current touch status for comparison in the next iteration.
    • Debugging Information (Optional Section):
      Serial.println();
      Serial.println();
      delay(100);
