I2C LCD1602
Overview
In this lesson, you will learn about Liquid Crystal Displays (LCDs) with an I2C interface. These types of LCDs are widely used in a variety of electronic devices, such as digital clocks, microwave ovens, car dashboards, and even industrial equipment. The I2C interface simplifies the wiring and connections, making it more convenient and efficient for hobbyists and professionals alike.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
I2C LCD1602
../_images/14-i2c_lcd_bb.png
Schematic Diagram
../_images/14-i2c_lcd_schematic.png
  • You can open the file 14-i2c_lcd.ino under the path of elite-explorer-kit-main\basic_project\14-i2c_lcd directly.
To install the library, use the Arduino Library Manager and search for “LiquidCrystal I2C” and install it.
14-i2c_lcd.ino
 1/*
 2  This code initializes and sets up a Liquid Crystal Display 16x2 with an I2C interface
 3  using the LiquidCrystal I2C library. And prints "Hello world!" and "LCD Tutorial" on the
 4  first and second lines of the display.
 6  Board: Arduino Uno R4
 7  Component:  Liquid Crystal Display 1602 with I2C Interface
 8  Library: https://www.arduino.cc/reference/en/libraries/liquidcrystal-i2c/ (LiquidCrystal I2C by Frank de Brabander)
 9*/
10
11#include <LiquidCrystal_I2C.h>
12
13LiquidCrystal_I2C lcd(0x27, 16, 2);  // initialize the Liquid Crystal Display object with the I2C address 0x27, 16 columns and 2 rows
14
15void setup() {
16  lcd.init();       // initialize the LCD
17  lcd.clear();      // clear the LCD display
18  lcd.backlight();  // Make sure backlight is on
19
20  // Print a message on both lines of the LCD.
21  lcd.setCursor(2, 0);  //Set cursor to character 2 on line 0
22  lcd.print("Hello world!");
23
24  lcd.setCursor(2, 1);  //Move cursor to character 2 on line 1
25  lcd.print("LCD Tutorial");
26}
27
28void loop() {
29}
After the code is uploaded successfully to the Arduino, the Liquid Crystal Display (LCD) will show the message “Hello world!” on its first line and “LCD Tutorial” on its second line.
If the LCD does not display any characters after uploading the code, you can adjust the contrast by rotating the potentiometer on the I2C module until the LCD functions correctly.
Code Analysis
  1. Library Inclusion and LCD Initialization: The LiquidCrystal I2C library is included to provide functions and methods for LCD interfacing. Following that, an LCD object is created using the LiquidCrystal_I2C class, specifying the I2C address, number of columns, and number of rows.
  2. Setup Function: The setup() function is executed once when the Arduino starts. In this function, the LCD is initialized, cleared, and the backlight is turned on. Then, two messages are displayed on the LCD.
