TA6586 - Motor Driver Chip¶
TA6586 is a monolithic IC designed for driving bi-directional DC motor. It has two pins of logic inputs for controlling the direction, forward and backward. The circuit feature good anti-interference performance, small standby current and low output saturation pressure drop. It has a built-in clamp diode to reverse the impact of the release of inductive load current, making it in the drive relays, DC motors, stepper motors or control the use of switching power safe and reliable. TA6586 is suitable for toy vehicles, remote-controlled aircraft motor drive, automatic valve motor, electromagnetic lock drive, precision instruments and other circuits.
Features
Low stand-by current: ≦2uA
Wide supply voltage range
Built-in Brake Function
Thermal Shutdown protection
Over Current Limit and Short Circuit Protect Function
DIP8 Pb-Free package.
Pin Function
Input Truth Table
Example
Motor (Basic Project)
Water Pump (Basic Project)
Smart Fan (Fun Project)
Plant Monitor (Fun Project)
