Passive Buzzer
Overview
In this project, use these two functions to make the passive buzzer vibrate and produce sound. The function tone() generates a square wave with a specified frequency (and 50% duty cycle) on a pin. A duration can be specified, or the wave continues until noTone() is called.
Similar to the active buzzer, the passive buzzer also utilizes electromagnetic induction to operate.
The difference is that a passive buzzer does not have its own oscillating source, so it will not emit sound if DC signals are used.However, this allows the passive buzzer to adjust its own oscillation frequency and produce different notes such as “do, re, mi, fa, sol, la, ti”.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
When connecting the buzzer, make sure to check its pins. The longer pin is the anode and the shorter one is the cathode. It’s important not to mix them up, as doing so will prevent the buzzer from producing any sound.
Schematic Diagram
You can open the file
16-passive_buzzer.inounder the path ofelite-explorer-kit-main\basic_project\16-passive_buzzerdirectly.Or copy this code into Arduino IDE.
The
pitches.hfile is also required — place it in the same directory.
Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 49
1/*
2 This code plays a melody on a passive buzzer module connected to an Arduino Uno board.
3 The melody is played once in the setup() function and consists of eight notes with
4 different durations.
6 Board: Arduino Uno R4
7 Component: Passive buzzer module
8*/
9
10#include "pitches.h"
11
12const int buzzerPin = 9;
13
14// notes in the melody:
15int melody[] = {
16 NOTE_C4, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4
17};
18
19// note durations: 4 = quarter note, 8 = eighth note, etc.:
20int noteDurations[] = {
21 4, 8, 8, 4, 4, 4, 4, 4
22};
23
24void setup() {
25 // iterate over the notes of the melody:
26 for (int thisNote = 0; thisNote < 8; thisNote++) {
27 // to calculate the note duration, take one second divided by the note type.
28 //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
29 int noteDuration = 1000 / noteDurations[thisNote];
30 tone(buzzerPin, melody[thisNote], noteDuration);
31 // to distinguish the notes, set a minimum time between them.
32 // the note's duration + 30% seems to work well:
33 int pauseBetweenNotes = noteDuration * 1.30;
34 delay(pauseBetweenNotes);
35 // stop the tone playing:
36 noTone(buzzerPin);
37 }
38}
39
40void loop() {
41 // no need to repeat the melody.
42}
At the time when you finish uploading the codes to the R4 board, you can hear a melody containing seven notes.
Code Analysis
Including the pitches library: This library provides the frequency values for various musical notes, allowing you to use musical notation in your code.
Please place the
pitches.hfile in the same directory as the code to ensure proper functioning. pitches.h
Defining constants and arrays:
buzzerPinis the digital pin on the Arduino where the buzzer is connected.melody[]is an array that stores the sequence of notes to be played.noteDurations[]is an array that stores the duration of each note in the melody.
const int buzzerPin = 8; int melody[] = { NOTE_C4, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4 }; int noteDurations[] = { 4, 8, 8, 4, 4, 4, 4, 4 };
Playing the melody:
The
forloop iterates over each note in the melody.The
tone()function plays a note on the buzzer for a specific duration.A delay is added between notes to distinguish them.
The
noTone()function stops the sound.
void setup() { for (int thisNote = 0; thisNote < 8; thisNote++) { int noteDuration = 1000 / noteDurations[thisNote]; tone(buzzerPin, melody[thisNote], noteDuration); int pauseBetweenNotes = noteDuration * 1.30; delay(pauseBetweenNotes); noTone(buzzerPin); } }
Empty loop function: Since the melody is played only once in the setup, there’s no code in the loop function.
Feel free to experiment with altering the notes and durations in the
melody[]andnoteDurations[]arrays to create your own melodies. If you’re interested, there is a GitHub repository (robsoncouto/arduino-songs ) that offers Arduino code for playing various songs. While their approach may differ from this project, you can consult their notes and durations for reference.
