Tilt Switch
Overview
In this lesson, you will learn about tilt switch. Tilt switch can be used to detect whether objects tilt, which is of great value in practical applications. It can be used to judge the tilt of bridges, buildings, transmission line tower and so on, so it has an important guiding function in carrying out maintenance work.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Fritzing Circuit
In this example, digital pin 2 is used to read the signal of Tilt Switch.
Schematic Diagram
You can open the file
04-tilt_switch.inounder the path ofelite-explorer-kit-main\basic_project\04-tilt_switchdirectly.Or copy this code into Arduino IDE.
1/*
2 The code monitors the state of a tilt switch connected to an Arduino.
3 It initializes a serial communication for debugging and sets a designated
4 digital pin as an input for the tilt switch. The state of the tilt switch
5 is continuously read and sent to the serial monitor.
7 Board: Arduino Uno R4
8 Component: Tilt switch
9*/
10
11const int tiltPin = 2; // Declare and initialize the pin for the tilt switch
12
13// Initialize the serial communication and set up the tilt switch pin as input
14void setup() {
15 Serial.begin(9600); // Initialize serial communication at 9600 baud rate
16 pinMode(tiltPin, INPUT); // Set the tilt switch pin as an input
17}
18
19// Continuously monitor the tilt switch state and output it to the serial monitor
20void loop() {
21 int tiltState = digitalRead(tiltPin); // Read the state of the tilt switch
22 Serial.println(tiltState); // Send the tilt switch state to the serial monitor
23 delay(10); // Wait for 10 millisecond before the next read
24}
Once the codes are uploaded to the uno r4 board, you can open the serial monitor to view the pin readings. The readings will display either “1” or “0” depending on whether the Tilt Switch is in a vertical position (with the internal metal ball making contact with the Wire Pins) or tilted.
